Author Subject: Help with electric window please
Cjwatson27
I'm having a problem with the drivers window it keeps popping out of its runner near the b pillar ive replaced the little grey guide/clip has it was broken got it all back together and it jumped straight back out, ive tried it again and same thing it feels as if the window is binding slightly has it goes down and back up Dunno anyone got any ideas Wink
Posted 22nd Aug 2015 at 20:29
Cjwatson27
I might just swap the door from the diablo hate messing around with door electrics I just know something else will go wrong
Posted 23rd Aug 2015 at 09:34
cully
rubber bush in the glass that fits on the lift pin missing?
Posted 23rd Aug 2015 at 11:40
Cjwatson27
Spot on mate just had it apart again plus the bottom of the rail ear the hinge looks damaged, going to grab a whole new workings replace the lot has it looks like it's been attacked a few times before.
Don't suppose any ones got a picture of the inside of the door some of the weather proofings missing round the speaker, so it's letting water in, just so I know what to get.
Thanks
Posted 23rd Aug 2015 at 15:10
Cjwatson27
Anyone know where I can get one of those exploded view picture showing all the parts and numbers for the door ?
Posted 23rd Aug 2015 at 20:00
lj_6
Check out the peugeot service box buddy! All the pictures are on there along with the part numbers.
Astra burg #365 Garrett Power
'99 bodied 6 track project
Posted 23rd Aug 2015 at 20:02
cully
Posted 23rd Aug 2015 at 20:57
Cjwatson27
Thanks cully
Posted 23rd Aug 2015 at 21:20
Cjwatson27
None of this has worked the f##king thing still pops off the rail near the b pillar, any ideas ive replaced the grommet, the white plastic thing is ok no wear, ive put a new grey guide thing in, even tho it keeps popping out from there should i try another one or could it be the seals there self i taken them off and made sure there clean even put some cooking oil in the channel put still it pops out.
Posted 26th Aug 2015 at 17:47
cully
front leading edge of the class runs in a channel is is fixed at both ends and tight,is the glass in the channel?
something is letting the glass tip pulling the clip off the back edge
Posted 27th Aug 2015 at 07:34
Cjwatson27
Yeah it's in there, it just seems that the front comes down first every time pulling the glass out of that clip, ive got a new guide coming when ive fitted that I'll see if I can adjust that front channel
Posted 27th Aug 2015 at 08:18
mocinim
Check yor rivits on the motor bracket seem to remeber having this as an issue on an xsi turned out one rivit had moved but was jammed in place looked fine but wasnt inline
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 27th Aug 2015 at 09:14
