Author Subject: Pug planet
jeffers Forum Admin
Has anyone around the Leeds area got pug planet software and all the gubbins to interrogate my car with? I'm at the end off tether with a fault and I think this'll be the best way to get to the bottom of it....
Team Running Engine again!
Team Negative Camber!
Posted 20th Aug 2015 at 22:42
pug_306
What's the fault buddy ?
1992 205 GTi6
205 Turbo 340bhp
Posted 21st Aug 2015 at 06:11
jeffers Forum Admin
Well, it's a long story but basically once warm it won't idle, it's a b**ch to start once it's warm and it seems to be over fuelling. I've changed the icv for a a new marelli one, new cts, new lambda, swapped TPS for a known good one, new map known good vss known good engine loom.... Absolutely at the end of my tether....
*Edit* Compression test when hot came back spot on..... Dunno
Posted 21st Aug 2015 at 08:02
Could it be a mapping issue? Dunno
Posted 21st Aug 2015 at 08:15
jeffers Forum Admin
Well that's a possibility, to be honest if I don't find anything soon, I'm abandoning the plan of Trackdays before the end of the year and fitting my bodies etc and going aftermarket. It's only getting mapped once so.... Oh steve il pm u now need to pick ur brain!
Posted 21st Aug 2015 at 08:18
its a standard ecu and engine, so wont be mapping?
Posted 21st Aug 2015 at 08:34
jeffers Forum Admin
It was remapped for pt81's by Wayne Schofield before I got the cams and ECU..... But I've no idea what the cams were set to or anything....
Posted 21st Aug 2015 at 09:08
they should be set to whatever lift @ tdc is stated on the specs.
standard FPR?
Posted 21st Aug 2015 at 09:50
jeffers Forum Admin
standard FPR?
They are set up as per the kent website. Yep the for is standard, although it was out of the car for around 12 month so I'm wondering if it's the diaphragm having dried out and cracked up, so I've another on it's way....
Posted 21st Aug 2015 at 10:32
anth
So runs fine on closed loop, until its warm and starts using open loop and sensors?
You tried unplugging the lambda, regardless of replacing it could, be a wiring fault.
Or maybe a small vacuum leak that only appears when things start heating up?
Posted 21st Aug 2015 at 18:00
jeffers Forum Admin
I see ur point but it's had a different wiring loom too.....
Posted 22nd Aug 2015 at 09:34
anth
Did you get to the bottom of this in the end?
Posted 28th Aug 2015 at 18:35
jeffers Forum Admin
Hmm not as yet, it's looking like the ecu is not mapped as I was told it had been when I bought it, no big problem in the grand scheme of things as I'll just put the standard cams in until I've bought an aftermarket ecu.... It's annoying more than anything else. Angry
Posted 28th Aug 2015 at 20:28
I ran Newman PH2's for two years without a map and had no issues whatsoever, they're not too dissimilar to a PT81.
Posted 28th Aug 2015 at 20:47
jeffers Forum Admin
I know that's the confusing bit... Il figure it out this week one way or another....
Posted 28th Aug 2015 at 22:05
