Author Subject: Land rover discovery parts
stuartdowers
Hi all,
having a big clear out and have loads of 300TDI Discovery parts, some of you probably own these for towing ya 306s about for track days.
still have loads of other smaller bits, but this is the main bulk, if ya need anything else just ask, am willing to post most parts for the cost of postage and package, ask for price or collection from Braintree Essex, CM7
ABS Pump £30.00
Air con condenser with receiver drier £40
Cranked rear radius arms (home bent) £30
Bottom rad hose/water pump/ expansion tank £10 x2
Heater motor blower full assembly for ac models £30 x2
Heater motor x3
Air filter housing £20
Inlet manifold £10 x3
Rocker cover and oil cap £10 x3
Standard length rear shocks pair £20
6 disc changer £30
Engine front cover £50 fan bearing like new
Viscous fan coupling and blade £20 x2
Heater matrix £20 x2
Steering column and uj's £20
Air flow meter £25 (0281002092) x2
Brake vac pump £30
Transfer mechanism £25
Transfer mechanism with bracket £30 x2
Auto gear selector £40
Washer bottle all 3 pumps £40
Washer bottle 2 pumps £30
Roof nets pair £10
Driver side mirror £20 x2
Rear radius arms £20
Front prop £40
Rear prop £20 x3
grab handles rear £10
Grab handle drivers side £10
Fuel filter housing £15
Fog lamp lens £30
Automatic crank shaft sensor0261210028 £30
Fuse box £25
Fuel pressure sensor 0281002063 £30
Prop coupling almost new £20
Grill £20
Rear Barke hose +40mm £20
Clocks £20 x2
Head lamp drivers side £15
Roof grab handles £20
stu
Posted 19th Aug 2015 at 08:20
phil b
pics of diff selector......
'97 PH1 'Sigma Blue' 306 GTI 6 project 'Tooters'
194.2bhp 127.6 dB
'96 PH1 'Black Noir' 306 DTurbo (project in permenant storage)
'94 300tdi LR Discovery (project gone dead and buried)
'99 td5 LR Discovery 2 (trailer tug and family bus) project 'in the garage getting chassis welded' (again)
The 6 can go fast, the disco can go anywhere
Built: 9 January 1997 - that's a Thursday
Skip Brown cars: tarporley Cheshire Tel: 01829 720492
add me --> philbrindley85@hotmail.com
TEAM: Snapper Sad
Posted 31st Aug 2015 at 21:22
stuartdowers
hi phil, due to image size cant upload, I have 3 in total, can you send me your email address and I will send pics
stu
Posted 1st Sep 2015 at 10:56
