Author Subject: stereo remote stick wiring
mocinim
Hi gent have no sound to my speakers have tested the door wiring replaced both sets of wiring in the front door gater jams
i get a slight plip noise from my front speakers when firing up the stereo all speakers have been switched out and tested
last resort control stick behind steering wheel anyone have a wiring diagram
cheers
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 16th Aug 2015 at 15:37
aaron6
Just disconnect the stalk. That will tell you if the stalk is at fault.
Posted 16th Aug 2015 at 16:59
mocinim
Its not currently connected pulled up the carpet by the drivers side door and found some botched taped wiring need some advise on how it should be
when testing the speaker wires and buzzing them out to earth im guessing i should not be getting continuity does the speaker wiring run in parallel or series
in addition there is a purple wire i believe is for the rear speaker has been cut and a blue wire has been run through any one know what colour the rear speaker wires should be
Im guessing i have an earth fault down there somewhere need some guidance
will be appreciated
Posted 17th Aug 2015 at 00:02
cully
dont rely on colours as peugeot didnt use colours to identify wires they used numbers Wink
the numbers are printed along the length of the wire they are easy to rub off so go carfull handling wires Wink
wire numbers for...
left hand rear speaker
845.
846
right hand rear speaker
847.
848
driver´s front door speaker
841
842
passenger´s front door speaker
843.
844.
Posted 17th Aug 2015 at 11:25
mocinim
Superb cully thats exactly what is required thanks muchely chap
Posted 17th Aug 2015 at 13:10
