Author Subject: Misfireing issue
gardener22
Hi all
New to the forum Thumbs up
Having an issue with my 306 rallye misfiring, I have changed all 4 coil packs and fuel injectors but still no joy.
had it on a diog and it came up with knock sensor? is this a common fault? I thought the purpose of a knock sensor was to let you know if there is an internal issue with the engine.
So I guess the question is has anyone had similar issues and it was fixed after changing the knock sensor or am I wasting my time as the engine has died?
previous to this (although I don't think it related) I have an idle issue - it drops revs and stalls when I drop the clutch coming up to junctions.
I changed all the usual suspects for this ICV, TPS, Map Sensor, disconnected power steering etc. but yet I still have the problem - Any idea's and do you think they are related?
Thanks is advanceBig grin
Posted 10th Aug 2015 at 17:37
mocinim
Can assume you used oe parts and you checked and changed your sparks
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 10th Aug 2015 at 23:13
mocinim
O and welcome to the forum Smile
Posted 10th Aug 2015 at 23:16
gardener22
Hi, yes used oe parts and changed spark plugs - got knock sensor for £40 so may as well try that but not confident it will cure it. My brother had a look and he thinks it could be a valve gone.
Have u ever heard of a knock sensor going? My brother seems to think they should never really go?
Thanks for the welcome 😀
Posted 11th Aug 2015 at 06:41
Have you tried a compression test?
Mine was misfiring the other day, tried coil packs and injectors which made no difference so i did a compression test and sure enough the head gasket had gone between cylinders 3&4. Doh
Posted 11th Aug 2015 at 06:50
gardener22
Hi - I have done a compression test but before it started misfiring - might be worth checking again now.
Posted 11th Aug 2015 at 07:59
pug_306
Could be fuel pump / ignition relay had a gti6 the other day with a misfire that I was sure was a coil pack turned out to be the relay. It's bolted to the back of the battery box
1992 205 GTi6
205 Turbo 340bhp
Posted 11th Aug 2015 at 08:15
gardener22
Didn't think of relay - I will check that also, I have the knock sensor so may as well fit that now to eliminate. Thanks
Posted 11th Aug 2015 at 09:18
woody.
I had my car on diag aaggeesss ago and have been meaning to check the knock sensor, I was told it is more likely the wiring so give that a check too.
Will be interesting if it cures your problems
Posted 12th Aug 2015 at 13:37
gardener22
Knock sensor changed and as suspected no change - compression check next - any other country ideas?
Posted 15th Aug 2015 at 09:57
pug_306
Compression check first that will tell you alot. If all good did you try a relay ?
1992 205 GTi6
205 Turbo 340bhp
Posted 15th Aug 2015 at 10:42
gardener22
No not really sure how to test it?
Posted 15th Aug 2015 at 11:59
Have you got a compression tester?
I'm not 100% sure what thread our spark plugs are but i'd guess that this will do the job:
http://www.amazon.co.uk/Draper-37442-Compression-Tester-14X18mm/dp/B0001K9TV0/ref=sr_1_2?ie=UTF8&qid=1439638307&sr=8-2&keywords=compression+testers
Simply remove all spark plugs from the engine, disconnect the wiring from all four injectors, screw the compression tester into the spark plug thread for cylinder 1, hold the throttle fully open and turn the engine over a few times, you'll see the gauge shoot up. Then press the release button to release the pressure and move onto the next cylinder. (This is much easier with someone to crank the car over whilst you look at the gauge).
All four cylinders should be within 10% of each other (i think).
For reference when i did my car before i replaced the head gasket i had the following:
Cyl 1 = 200psi
Cyl 2 = 185psi
Cyl 3 = 100psi
Cyl 4 = 100psi
I could actually hear the air gushing out of the other cylinder when i was doing cylinders 3&4.
I took the head off and this was the culprit:
If all four cylinders are up around 180-200psi then i doubt its your head gasket at fault.
Posted 15th Aug 2015 at 12:38
gardener22
Thanks - It was the relay I wasn't sure how to test - I've done the compression test and cylinder 1 & 2 have 60 psi and the other 2 around 170 so I'm guessing my head gasket is probs gone as well.
Posted 16th Aug 2015 at 15:57
gardener22
Posted 17th Aug 2015 at 14:12
