Author Subject: Cams in after head bolted down
May be a daft question but here goes:
My head gasket has gone on my daily driver, so the other night I whipped the head off and got it to the machine shop. All valves are straight and it's passed the pressure test. They're now going to chemical clean it, skim it and fit new stem seals and exhaust valve guides as they were apparently quite worn, then lap the valves back in and return it to me.
The question I have is; can I mount the base of the head to the block before fitting the cams, then put the cams in somewhere close to where their locked position would be and clamp down the carriers, then lock them properly before fitting the cambelt?
Or am I best fitting the cams and carriers with the head off the car and the cams in their locked positions then putting the head on?
Only reason I asked is that it seems like it could be a daft idea trying to put the head on when the cams are in as there's potential of catching a valve on the gasket/block when placing it down, and I don't fancy having any bent valves after this recent expense.
Cheers for any advice Thumbs up
Also, I assume the cam seals just tap in once the carrier is clamped down rather than placing it in the head then clamping the carrier down on top of it?
Posted 4th Aug 2015 at 22:39
mechanical_repairs
I bolt the head down without the cams in, them fit them afterwards, the way the engine times up ie the Pistons in the middle of the bore it's hard work to bend valves that way. Just make sure you don't get valve tangle. Inlet and exhaust valves
Carl
Posted 4th Aug 2015 at 22:41
pete_rallye
I assume were talking standard cams here? Personally I would put the cams in first with the seals and everything in place, lock them in position (if standard, otherwise time them up somewhere near),then place the head on the block. Again, assuming standard cams. the valves won't be open much and you'll really have to chuck the head on to hit them on the block. I've had the head on and off a block more times than I care to remember with 12mm lift cams in (timed to about 4mm and 3.5mm lift inlet and exhaust) and never hit them.
My reason for this is as Carl mentions; my main concern is the valves hitting each other more than the valves hitting the pistons, especially with higher lift cams in, and doing it all then placing the head on allows you to watch the valves so you don't clash.
Lap of the 'ring
Posted 4th Aug 2015 at 23:44
Yeah I'm just using the standard cams.
Thanks for the advice Thumbs up
Posted 5th Aug 2015 at 06:58
jeffers Forum Admin
I can see reasons for both, personally if the engines in the car I put the cams in after fitting the head, exhaust cam first as close to being the locking position as you can, fit the carrier then time up and lock the pulleys but it's all down to what u feel comfortable with.
Team Running Engine again!
Team Negative Camber!
Posted 5th Aug 2015 at 07:55
mechanical_repairs
I also find without the cams in you can easily fit the exhaust manifold from the top with just a 13mm ratchet spanner, there are reasons for my madness.LOL
Carl
Posted 5th Aug 2015 at 09:33
