Author Subject: Cutting Out!
eddy_gti6
Had this problem for about 2 weeks bow. When I go round a sharp right bend the fuel pump seems to cut off then kick back to life again then last friday the car cut out all together and wouldnt startt all. Fuel pump wouldnt prime. Sorted this problem the fuse had blown so pump would prime but car wouldnt start. Plugged the computer in and I was getting no reading for engine speed, fitted a new crank sensor and the car started but took a few goes. The car still cuts out round hard right hand corners. Any thoughts to what my problem could be?
Posted 3rd Aug 2015 at 20:54
mocinim
Sounds like something is swaying when you corner then reconnecting when you straighten up could also be the cause of your blown fuse have you checked the wiring at the pump
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 3rd Aug 2015 at 22:54
eddy_gti6
Loom inside the car is fine. Also tried a brand new pump in. Still not fixed the problem
Posted 3rd Aug 2015 at 23:14
eddy_gti6
Got it down to a wiring fault somewhere as something is blowing the fuel.pump fuse. I have a feeling it could be the fuel pump relay as it is cracked and could have water getten in
Posted 4th Aug 2015 at 20:16
