Author Subject: Revs drop off very quickly when cold
RetroPug
This issue is difficult to describe but here goes:
Before the car is up to temperature, it idles fine and takes throttle input with no issues. What does happen though, is that lifting off causes a very sharp drop-off in revs, making smooth gear-changes a bit more tricky. I know this shouldn't really be happening. AFAIK the car isn't down on power when cold but could well be as I never rag it from cold anyway.
The car developed running issues when cold very shortly after I first purchased it. These went away after fitting a new CTS and a new ICV. I also have what I think is a good TPS from my other 306 that ran absolutely perfectly fitted which I also was using over the winter to try to diagnose cold-running sluggishness.
All of the above worked and the car has been fine but this slight drop-off in revs was still bugging me but then the car came off the road for a fair bit.
Could this possibly be lambda-related? I've seen another thread regarding being down on power from cold which got me thinking. I'm not sure what other sensors could be affecting this.
Posted 2nd Aug 2015 at 21:41
RetroPug
No ideas?
To add, coilpacks were also swapped for a known good set which massively improved cold running.
Posted 7th Aug 2015 at 15:29
could be map sensor, ideal way to diagnose is PP2000 and compare expected values with actual values.
Posted 7th Aug 2015 at 16:27
jimmyrallye
Had a similar problem with my 6 was the map sensor
Posted 7th Aug 2015 at 19:14
mocinim
Had a simular issue once with an xsi found it to be the cheep ICV i installed worked well for a while but had to buy twice in the end ; (
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 8th Aug 2015 at 12:05
RetroPug
Hmm okay, I did swap the map with one off a car that seemed to be running fine ages ago, but then that may not have been a great one anyway.
I'll bear the MAP in mind.
It isn't the ICV, ICV worked fine and then was replaced with a brand new magnetti marelli one.
Posted 8th Aug 2015 at 14:25
mocinim
Quite keen to learn the relationship function between the lambda the map the icv through the ecu i presume the lambda has a preheat so if this is faulty and is confusing the ecu whilst the engine is cold would this be the cause of you loss in power eg the lambda is telling the ecu there is to much fuel coming in and shuts down the flow this in turn telling the icv the air flow need adjusting !! How does the map relate to each of these
Thought id ask whilst your on the subject sorry to bomb your thread however should think the answer will be related to your issue
Not a mechanic but pretty good with micro process control systems this seems simular in function
Posted 8th Aug 2015 at 23:09
