Author Subject: No power for first 30 meters/30 seconds.
Kenan
When I start the car from cold and pull away without mucking about the car has no power for the for first 30 meters. However if I sit on the drive for 30 seconds (playing with stereo etc) and then pull away there is no issue. Also when starting when hot she can sometimes turn over a fair few times before starting.
I recently had the exhaust changed and the lambda sensor was changed to the one that came with the exhaust, is this the likely culprit?
Posted 2nd Aug 2015 at 07:50
mocinim
yea could be Lambda sounds likely that your heating element is faulty
Found this its a little off due to being about a twin lambda instead of the 306 only has precat but thought it was good anyway
http://m.youtube.com/watch?v=Fl3aD1qJrEg
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 2nd Aug 2015 at 09:41
Kenan
Thanks for the reply.
Didn't know they were £60 new, anyone know where they are cheaper (other than second hand)?
Posted 2nd Aug 2015 at 17:39
check the tech
Had the same issue with mine. Wouldn't bother with the cheaper ones if you can avoid it. Decent Bosch unit and no worries! Buy cheap buy twice.
Posted 2nd Aug 2015 at 17:43
mocinim
This is one of the parts of the management system you dont want to go cheep with stick with bosch as tech said
Posted 2nd Aug 2015 at 21:14
Kenan
Bosch unit it is, got the MOT week Monday will be interesting to see what happens with the current unit......
Posted 2nd Aug 2015 at 22:05
not likely to be the lambda as its not used on cold starts.
Posted 3rd Aug 2015 at 10:06
scotzman
Is there any steam/white smoke from the exhaust on a cold start? Is it using any water?
Posted 3rd Aug 2015 at 10:32
Kenan
No more than I'd expect under normal operation .
Cars in the garage on Monday I'll get them to see if there are any error codes...
Posted 3rd Aug 2015 at 19:45
mocinim
Would still say lambda mine had a very simular issue lambda fixed it not going against welshpugs knowledge he will know way more than i but never the less fixed my issue
Posted 3rd Aug 2015 at 20:17
