displaying posts 26 to 50 of 109
Pages (5): 1 [2] 3 .. last
Author Subject: Gearbox for highboost!
superchargedblack1997gti6
When I turn wheel by hand?
Posted 25th Jul 2015 at 20:35
rich_w
Some do that, depends on design and preload if it's a plated diff.
Contact Details:
07732 822546
Posted 25th Jul 2015 at 20:46
fatlapit
I agree with rich. Personally ive only broke 2 boxes one was a gti6 one and more recently the hdi box. Hdi box lasted 4500k but failed at coombe on the 93rd lap. Currently trying to find a solution with yune gears
Posted 25th Jul 2015 at 22:14
rallyeash
Yep. Don't be too hasty!
I personally don't think it'll be 'that' bad
309 3dr K20 Type R
Posted 27th Jul 2015 at 11:06
Describe not too bad lol. Only done 1000miles on a fresh gearbox fresh diff. Thinking the oil overheated possibly. But as you say have to wait gearbox should be out tonight have a standard one to go in but we will see what happens. Thinking it may need an external oil cooler and pump to keep it cooler!
Posted 27th Jul 2015 at 11:41
you need to figure what the problem is first, get some temperature strips on the casing and use it.
Posted 27th Jul 2015 at 11:45
fatlapit
My box was at about100 degrees at coombe. Got an oil coole circuit set up already. Trying to make internal spray bars atm.
Posted 27th Jul 2015 at 12:52
Good luck Ross ...hope it's not as bad as your thinking m8 Thumbs up
Posted 27th Jul 2015 at 13:58
Knowing my luck mate probably worse 😀
Posted 27th Jul 2015 at 13:59
Post #35
NOooo you have got this far Ross & a thing of Beauty you have made ...keep your chin up ...it's not Cancer m8 ...
It will get sorted Thumbs up
Keep us all updated later m8 Thumbs up
Posted 27th Jul 2015 at 14:16
Post #36
I use a standard gearbox on mine, Miles from here reconditioned it and shot peened and coated the gears for strength.
That was at the beginning of 2009, did a year of high boost with it and then been super high boost since 2010 - it's had 2012 and 2014 off the road but was used very hard in 2010, 2011 and 2013. Cool
Posted 27th Jul 2015 at 17:40
Post #37
I don't think my hard and you're hard are the same Stan Smile. Mine had miles take apart and fit some new bearings 1000 miles ago. But I can now confirm it has broken my lsd! And the gearbox is also broke! Will take more photos off it tomorrow.
Posted 27th Jul 2015 at 17:44
pugheaven
Post #38
Ah man that's s**t, now we need to know what went first! I really hope it wasn't the straight cut gears at fault
Posted 27th Jul 2015 at 17:52
cully
Post #39
something in my mind is saying shouldnt put LSD cars on a rolling road!
going off to dig up info as I remember being told this somewhere
Posted 27th Jul 2015 at 18:17
devere
Post #40
You are probably thinking of mot testing brake rollers...
Posted 27th Jul 2015 at 18:26
cully
Post #41
ah! yes MOT LSD on roller brake testers
Thumbs up
Posted 27th Jul 2015 at 19:03
Post #42
Well that (could )be why the lsd broke then as Wayne did an emergency stop from 153 mph on the rollers when the gearbox broke lol but I think it was something else myself?
Posted 27th Jul 2015 at 19:51
rallyeash
Post #43
Why did he do an emergency stop?
309 3dr K20 Type R
Posted 27th Jul 2015 at 20:00
allanallen
Post #44
LSD should be fine on the rollers, it's brake testing they don't like, when you stop hold one wheel and spin the other.
Facebook
Posted 27th Jul 2015 at 20:01
rich_w
Post #45
Is the diff broke? What's broke on it? Braking on the rollers won't cause a diff to break, both wheels are turning at the same speed. The limiting factor is also traction, and one would hope it takes more force to break your diff than it does to break traction , otherwise your diff wouldn't last very long...
Contact Details:
07732 822546
Posted 27th Jul 2015 at 20:03
Post #46
So sorry to hear this Ross Thumbs down
Really was hoping it was something simple & cheap M8 ...
Keep us all updated Ross !!!!!!
Really am gutted for you Ross ...try to keep positive m8
Posted 27th Jul 2015 at 20:14
pete_rallye
Post #47
You mentioned one of the CV joints had sprayed grease everywhere? Is the rest of the driveshaft ok? If it snapped or failed, the sudden transfer of load into the other driveshaft could potentially break a diff but it'd be unusual, I'm sure they come across greater forces on rally stages!
Lap of the 'ring
Posted 27th Jul 2015 at 20:20
Post #48
ML gearbox time? Or maybe a Saab one?
Treating gears basically does nothing unless they are brand new. Even then we've found it to be pretty useless.
Ended up using entire new gearsets custom built for the task but even those have issues over 900lbft
Posted 27th Jul 2015 at 20:23
Post #49
I doubt they are rated for that much torque.
Posted 27th Jul 2015 at 20:29
Post #50
Thinking mr2 turbo or I've found a ml sequential that may take the torqu but not looking at getting that very quickly at 12k Sad
Posted 27th Jul 2015 at 23:47
