Author Subject: Flat Battery / Alternator?
matt16v
Hi all,
Having some problems with the '6 recently. Battery is only a few months old. I've charged it with a charger and then put it in the car. Worked fine for 5 days or so and then on the last day, each time I start it I hear it struggling more and more for 3 or 4 starts until it barely turns over, like a flat battery. Sometimes this magically cures itself and seems to just charge all of a sudden, regardless of distance traveled.
For example, left work on Friday and it sounded as though it was starting to struggle, 5 miles home and then went out later that evening, 3 miles struggling more so, 5 miles struggling even more and then won't start, so I jump it. Drive 0.5 miles home and then I manage to start it fine 3 consecutive times on my driveway, jumping into life as if nothing is wrong.
Any ideas?
1999 Astor Grey GTi-6 OEM+
Posted 21st Jul 2015 at 18:33
Bad earth ? Check the chassis and gearbox earths bud
Posted 21st Jul 2015 at 20:14
6waysforward
I had this a few years ago. It was the live stud on the starter had broken inside the solenoid so it looked fine.
One min is was making a good connection, next min it moved and wouldnt let the current from the alt back to the battery resulting in lots of flat battery issues.
Or bad earths as chris said.
Possibly the battery is s**t if its been left flat for a while.
Posted 21st Jul 2015 at 22:24
matt16v
Will give the earth's a check. It starts 100% reliably if I'm jumping it. Also, what does the red battery light mean on the dash? It never comes on when driving but on ignition sometimes it is much brighter than other times. I think once it was completely extinguished but it still started fine!
Posted 22nd Jul 2015 at 07:17
matt16v
Not checked the earths yet but it's now hunting up to about 2k at idle now. Any ideas?
Posted 23rd Jul 2015 at 00:24
Check your battery connections
Put a jump lead between the battery earth terminal and the engine to check earth
Look for an air leak between head and throttle butterfly
Posted 23rd Jul 2015 at 22:49
matt16v
Couple of videos
Here is it starting - https://vid.me/qhc1
Hunting did this the whole 5 miles home yesterday - https://vid.me/YESj
Thanks for advice, will check it this morning
Posted 25th Jul 2015 at 08:37
matt16v
Ok I've checked the earths and battery connections, all tight and clean. Can't see any air leak either.
Started fine the last 3 or 4 starts but this morning it's bad as ever. Along with the revving in the above video, the fuelling is very rough. Coming on / off the throttle nearly snaps my neck in half. There's also a bit of a lag coming off the throttle where it'll continue to accelerate for a second or two.
I think the slow starting and this are linked as it runs beautifully when it starts well. Some sort of sensor issue?
Thanks
Posted 27th Jul 2015 at 08:24
Bad earth somewhere dude have you checked the earths on the gearbox and the ones under the battery tray ?
Posted 27th Jul 2015 at 10:11
matt16v
Doh, forgot the one under the battery tray, will get on it ASAP. Thank you!
Posted 27th Jul 2015 at 10:32
Should be one from negative terminal to gearbox and to the chassis under the gearbox ? Should also be 2 other earths on the gearbox desperate to the battery negative
Posted 27th Jul 2015 at 12:55
matt16v
This ended up being a faulty battery! Bit odd for a new battery to die. Got it replaced under warranty and now all is well.
Posted 10th Aug 2015 at 06:42
