displaying posts 101 to 117 of 117
Pages (5): first .. 3 4 [5]
Author Subject: High Boost GTI 6 Track Car PIC HEAVY
petey
Post #101
Little update...
Fitted the new wheels and tyres the other day and took a few pics
IMG_3533 - Copy by Peter Dodds, on Flickr
IMG_3534 by Peter Dodds, on Flickr
IMG_3545 by Peter Dodds, on Flickr
High Boost Supercharged 306 GTI6
Alfa 147 GTA
Posted 28th Mar 2018 at 14:39
petey
Post #102
Fitted a passenger seat
IMG_3572 by Peter Dodds, on Flickr
Then this week I took her out for a trackday at Castle Combe
PWPM2219 by Peter Dodds, on Flickr
EOKV2778 by Peter Dodds, on Flickr
GXGO6098 by Peter Dodds, on Flickr
IMG_3588 by Peter Dodds, on Flickr
TKFR7155 by Peter Dodds, on Flickr
It was savagely quick and the handling was fantastic, however it wasn't all plain sailing...
The brakes were struggling, getting very hot after a few laps ( I might have got a bit carried away on the 1st session Whistle ) so I came in and bled them.
I also got told off for being too noisy on the drive by sound test so had to take it easy out of camp and along the straight.
The clutch was slipping if I booted it too hard in 5th gear, so I carried on and used the day as a bit of a learning curve, not braking too hard/late and not giving it too much stick in 5th. It was still plenty quick enough and loads of fun!
Then later in the afternoon coming out of Old Paddock I lost all power and had to be towed in... Turned out to be a damaged crank position sensor, I'm guessing maybe part of the clutch might have flew off and hit it?!
VOTC1380 by Peter Dodds, on Flickr
So a few bits to sort before the next track day:
- New / quieter exhaust
- New stronger clutch
- Bigger brakes (although for now I might swap the Mintex M1155 pads for some Carbone Lorraine and see if there's any improvement)
Alfa 147 GTA
Posted 28th Mar 2018 at 14:59
Post #103
Was great to meet you at Combe Pete and the car looks brilliant m8 ...credit to you Thumbs up
I personally think your wasting your money changing pads ...You’ve got a high boost 415-460bhp engine in it and the clutch was slipping meaning it wasent no where near potential speed ....you need 310- but better (330mm) Radial mount Brembo Renault = Ash Hargreaves conversion / brakes to fit under pro1.2 /16s ....with a Endurance pad CL6e or Ferrodo DS1.11 would be my choice ....
I’d go AP clutch to ....not cheap and will need flywheel possibly?????
All you need is your centre box made bigger and back box checked packings not blown out or missing Thumbs up
Go careful though ...when your clutch grips it’s going to put so much pressure on everything including drive shafts and mainly Gearbox ...I know you got the straight cut gears etc but I think your not going to end up using all the power 415-460
Pete keep the updates coming and buy the best stuff now rather than finding out the hard way ...Thumbs up
Posted 28th Mar 2018 at 15:40
Post #104
I've killed a few crank position sensors over the years, they seem to be a bit of a weak link from my experience so i carry a spare in the helmet hammock and a 10mm ratchet spanner too Laugh
From my experience you'll not cook proper pads like the carbon lorraines or carbotech's, but like Damien mentioned it might be worth trying to get some bigger discs fitted as you'll be putting a lot of heat into them with them being a smaller diameter. If you are determined you can squeeze 315mm discs under some 15" wheels, i've managed 310mm under 15" pro race 1.2's.
If you haven't already, consider fitting some ducting for the front brakes, i fitted some that just blasted cool air from the fog light openings down some tube which was then tie-wrapped to the wishbones. It makes a noticeable difference from personal experience, i used to cook my DS2500's on standard calipers/discs 2/3 of the way round the nordschleife, after the ducting i could do a whole lap with no issues.
Nice update by the way, love the pic with the flame out the exhaust Thumbs up
Posted 28th Mar 2018 at 21:34
blandy
Post #105
Looks great what did you register at static noise?
Posted 28th Mar 2018 at 22:12
petey
Post #106
quote:
[quote="Day666"]Was great to meet you at Combe Pete and the car looks brilliant m8 ...credit to you Thumbs up
Good to see you mate, thanks for the advice... I have a little bit more work to do/money to spend!
Alfa 147 GTA
Posted 30th Mar 2018 at 10:10
petey
Post #107
quote:
[quote="prism7guy"]I've killed a few crank position sensors over the years, they seem to be a bit of a weak link from my experience so i carry a spare in the helmet hammock and a 10mm ratchet spanner too Laugh
I'll defo be getting a few spare crank sensors on order!
The pic with the flame is pretty cool I must admit Smile
Alfa 147 GTA
Posted 30th Mar 2018 at 10:13
petey
Post #108
quote:
[quote="blandy"]Looks great what did you register at static noise?
It was 92db static, but as you can hear from the video above the drive by was a different story altogether!
Alfa 147 GTA
Posted 30th Mar 2018 at 10:15
3rd time lucky
Post #109
Yea these sail through the static test but really struggle on the drive-by. It’s very tempting to get a new backbox with the tip pointing down at the ground.
BLACK RALLYE - Sold
CHERRY RALLYE - new toy
Posted 30th Mar 2018 at 12:30
petey
Post #110
Progress update!
315mm AP Racing brakes sourced
Helix Paddle Clutch sourced
16" wheels and tyres ordered
Pictures and more info to follow over the next month Smile
Alfa 147 GTA
Posted 20th Jun 2019 at 16:14
blandy
Post #111
What a car hopefully see you out on track these 306’s seem to be getting rarer in trackdays now
Posted 20th Jun 2019 at 19:42
petey
Post #112
Absolutely mate, I’m determined to get some more use out of it this year!
Alfa 147 GTA
Posted 21st Jun 2019 at 04:39
Post #113
never had a crank sensor fail myself!
I'd certainly be concerned if something has hit it.
Posted 21st Jun 2019 at 07:28
Post #114
I've had a couple of crank sensors fail on the track car in the past. I now carry a spare to all trackdays just incase.
Posted 21st Jun 2019 at 13:11
petey
Post #115
Ash has had one go on his 205 before on the road as well, that’s how we were able to diagnose it so quickly on the day. I’ll be carrying spares from now on
Alfa 147 GTA
Posted 22nd Jun 2019 at 06:55
Flatoutfarr
Post #116
car looks great, especially on those red Cyclones.
Adventure before Dementia !!
Posted 3rd Jul 2019 at 16:18
petey
Post #117
Thanks! Sadly they must go as I need 16” wheels to fit over my new brakes.
Want to buy them??? Smile
Alfa 147 GTA
Posted 3rd Jul 2019 at 16:31
