displaying posts 76 to 100 of 117
Pages (5): first .. 3 [4] 5
Author Subject: High Boost GTI 6 Track Car PIC HEAVY
petey
Post #76
Ben_W wrote:
Care to be a bit more descriptive?!
Ok stuff and things have happenedLOL
Oil cooler is sorted along with fan wiring and other bits and pieces, it's now Ready for MOT and a bit of road use but still needs oil change, injectors changed and uprated brakes and stronger gears fitted before it sees a track...
Oh and I have a satchshift sitting in my garage!
High Boost Supercharged 306 GTI6
Alfa 147 GTA
Posted 2nd Aug 2016 at 19:03
Post #77
About time LOL
I thought you'd given up ?
Ash is mountain biking & travelling also ....
Do you think it may be ready for Sept ?
I'm hoping to do Forge Action day to dial a few things I've done ...Thumbs up
Posted 2nd Aug 2016 at 19:13
rallyeash
Post #78
MOT Ready...
309 3dr K20 Type R
Posted 9th Aug 2016 at 12:02
Post #79
Won't get an mot without a number plate Razz
Posted 9th Aug 2016 at 12:30
Post #80
depends where you MOT it Whistle
Posted 9th Aug 2016 at 13:53
Post #81
Mine was struggling with coolant temps when driven hard for a long time since I went to high boost cooler or rather slightly bigger than norrmal high boost cooler... but I've changed it for a more sensible sized one. Also had the SC cooler behind the intercooler which won't have helped but wouldn't put the oil cooler there seems a stupid idea tbh.
Was it this car it was originally in front of the intercooler? Defeats the object doesn't it LOL
There is now airflow round the outside of the through the rad and I've blanked off the sides of the rad with plastic offcuts to force the air to go through the rad instead of past it. Also upped from.a.13 row to a 19 row oil cooler. Car is much happier but still think oil may get a bit too warm on track time will tell when I'm at brands soon.
May change to an open sandwich plate and maybe get more direct airflow to the oil cooler. The fact the car is low boost so standard compression running boost will always make for high temps anyway I would think.
Posted 9th Aug 2016 at 16:54
petey
Post #82
UPDATE
The 6 is MOT'd, taxed and insured Smile
Drove it 60 miles from Devizes to Bournemouth this morning with no issues other than it didn't like idling in traffic
Alfa 147 GTA
Posted 6th Sep 2016 at 10:30
Post #83
petey wrote:
UPDATE
Brilliant Pete .....
You doing Forge Action Day this Saturday ?....last one this year
Posted 6th Sep 2016 at 14:20
petey
Post #84
Afraid not mate, we're at the Nurburgring this weekend. Not with the track car I might add, she's not ready for a trip like this yet!
Alfa 147 GTA
Posted 9th Sep 2016 at 09:32
petey
Post #85
UPDATES!!!
So the GTI 6 is coming along nicely now, its been over with Rich Walker a few times and he has done some great work on it in the last 5 months.
The first visit last year to have some niggly bits finally sorted.
The wiring under the bonnet was checked and re-done where necessary then tidied up nicely:
Aluminium extension piece welded to the throttle body and correct filter fitted as well as a general under bonnet spruce up:
It now runs and idles much better.
New radiator fitted and charger cooler relocated and all cooling systems mounted properly on brackets:
Furthermore the following work has now been completed:
- Change engine oil & filter Silkolene Pro R 20W50 & OEM Peugeot Oil Filter
- Weber 3 Bar FPR
- NGK BKR7EIX Spark Plugs
- Bosch OEM Lambda Sensor
- Top engine mount welded/chocked
- Various Oil & coolant leaks sorted
- New Bosch 044 fuel pump and relay/wiring
Then last month it was over to Rich again to have the gearbox swapped, it now has KAD straight cut gears with phosphor-bronze bushings fitted along with new driveshaft seals, clutch for bush and OE Peugeot gear oil.
Oh and it now has a Satchshift which is decent:
The straight cut 3rd & 4th gears sound epic and altogether the car now drives very well, it's very quick.
Track day to do list:
- extended gearbox breather setup
- 4 pot brakes
- coilover suspension
- new tyres
At home after being treated to a wash
Alfa 147 GTA
Posted 5th Feb 2018 at 14:14
oliverharveyuk@hotmail.co.uk
Post #86
EPIC! Love
98 Blaze 6 - Current
Posted 23rd Feb 2017 at 15:59
Post #87
Thumbs up
Are we going to see you & your car out & about this year ?
Posted 23rd Feb 2017 at 20:31
petey
Post #88
Without a doubt mate Thumbs up
Alfa 147 GTA
Posted 24th Feb 2017 at 07:27
3rd time lucky
Post #89
Much love for this!
BLACK RALLYE - Sold
CHERRY RALLYE - new toy
Posted 24th Feb 2017 at 11:06
Chr1sch
Post #90
I have to say this looks bloody brilliant!
Posted 24th Feb 2017 at 11:14
3rd time lucky
Post #91
Carbon door cards would look great in there.
BLACK RALLYE - Sold
Posted 24th Feb 2017 at 11:43
Post #92
I've got some old ones off mine for Sale .....made by Twangy
Posted 24th Feb 2017 at 14:52
petey
Post #93
Thanks for the comments guys.
I have fitted windey Windows, let me know how much you want for the door cards mate
Alfa 147 GTA
Posted 25th Feb 2017 at 08:43
petey
Post #94
It's been a while, but things have happened...
Refurbed axle fitted:
- 21mm TBs
- Solid mounts
- Genuine Peugeot bearings etc
- Powder coated
- Lowered 30mm
The suspension has been overhauled and it now has Bilstein B8 dampers with Eibach -30mm springs
Stud and nut conversion all round
Willwood 4 pot conversion up front with new braided lines and Mintex M1155 pads
Also fitted an extended breather setup with filter to the gearbox and put in an additional 1 litre of genuine Peugeot gear oil
I thought I would go for some not very subtle track wheels, cyclones shot blasted and powder coated - the light in the pic makes them look pink - but they are a proper signal red colour
Now fitted with some brand new Dunlop DZ03 rubber Cool
I'll get some more pics up with the wheels fitted soon...
Alfa 147 GTA
Posted 5th Feb 2018 at 17:58
pug_306
Post #95
Looking good buddy . Are you planning on any trackdays soon ?
Btw your front discs are on the wrong way round.
1992 205 GTi6
205 Turbo 340bhp
Posted 5th Feb 2018 at 16:23
petey
Post #96
Cheers, yeh I'm hoping to get over to Castle Combe next month...
Oh yeh so they are! Doubt it makes any difference anyhow?!
Alfa 147 GTA
Posted 5th Feb 2018 at 18:02
Post #97
quote:
[quote="petey"]Cheers, yeh I'm hoping to get over to Castle Combe next month...
Peter looking great and PM me when your going to Combe I’ll come up for a nose m8 ....Thumbs up
What’s happened to Ash nowadays?...you spoke to him ...saw him at Combe on Saloon Race day 6months ago
Posted 5th Feb 2018 at 20:51
petey
Post #98
I see him most weeks, between work and all the running/training he does now he doesn't have much time for cars - although he is talking about re-commissioning the 205 to do some track days this year...
I'll let you know when I've booked a day, it will be its track debut so hopefully it goes smoothly...
Alfa 147 GTA
Posted 6th Feb 2018 at 07:14
tvrfan007
Post #99
Lovely car mate, should go well on track. My low boost hustles most stuff along - let me know if you ever get bored of it lol.
The brakes and tyres will give you a good edge in the corners, and you'll have tons of grunt in a straight line. Hope you have good brake fluid in the system.
Did you fit a Quaife diff in the end?
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 6th Feb 2018 at 09:48
petey
Post #100
Thanks I am really pleased with it now, unlikely I'll get bored I don't use it enough for that to happen!
The brake system has been completely bled through and all new fluid put in, can't remember the spec but it was the best that Merlins had when I went in.
Yeh Quaiffe ATB, should do fine for now
Alfa 147 GTA
Posted 6th Feb 2018 at 21:41
