Author Subject: Rebuilding trailing arms...
Ben_W
Formerly gpm
Guys,
Tomorrow I'm gonna be putting the new bearings into the beam and the shafts into the trailing arms.
Have a question about these little flange bits that go on the shafts.
Do you put them on first, or press the shaft in then add them? Is there a specific position in relation to the trailing arm, I.e. distance etc?
Posted 12th Jul 2015 at 21:38
press the shaft in to a 2mm clearance, then fit the cup bit against the arm.
Posted 12th Jul 2015 at 22:05
Ben_W
Formerly gpm
Cheers Mei.....assume its just a tap on jobbie?? Seems pretty tight on the shaft..
And by 2mm, I assume you mean 2mm inset from being flush on the other side of the arm, I.e. the direction you are pressing it?
Posted 12th Jul 2015 at 22:33
allanallen
Yep, 2mm inset from the outside of the arm. I usually use a piece of pipe that slides over the pivot tube to tap the cup on so it goes on even, they can be tight sometimes.
Facebook
Posted 13th Jul 2015 at 09:43
Ben_W
Formerly gpm
Thanks Allan
Posted 13th Jul 2015 at 09:22
Ben_W
Formerly gpm
Assume this looks about right then?
Posted 13th Jul 2015 at 15:16
allanallen
Thumbs up
Facebook
Posted 13th Jul 2015 at 15:29
jord294
which way have you pressed them in?
Posted 13th Jul 2015 at 20:22
Ben_W
Formerly gpm
Lol, I made extra sure I'd got them the right way round Andy.....
Posted 13th Jul 2015 at 20:41
Ben_W
Formerly gpm
Thanks all very much for the help so far.
One last question. Do these collars go tight up against the brackets on the beam tube?
Posted 13th Jul 2015 at 22:03
no, 2mm gap there too iirc, other way up also, look up my beam thread.
Posted 13th Jul 2015 at 22:19
Ben_W
Formerly gpm
Cheers Mei, I'd missed that.....
Posted 13th Jul 2015 at 23:42
jord294
on 306/xsara beams, that sleeve is the other way up (lip to outside edge)
205/309 different for some reason
good luck with rest of your build
Posted 14th Jul 2015 at 10:25
Ben_W
Formerly gpm
Thanks Andy, not far off now...
Just so I'm sure, the sleeves, inset 2mm from A or sitting 2mm above B (which would be the end of the beam tube?
Posted 14th Jul 2015 at 11:40
PAG306
Is there any particular reason this part isn't tapped flush upto the mount casting as i can't see any logical reason for it if the seal's fitted correctly in the other end & the gap clearance is set why would Peugeot make a part that's too short ? Roll eyes
Posted 24th Jul 2020 at 01:30
PAG306
Guess it's another one of lifes mysteries then lol
Posted 4th Aug 2020 at 12:56
miki4
I had the same question when I rebuilt my beam and there was no answer to it. I guess you end up having the wheels 2 mm nearer to the inner wheel arch. I tapped them on flush on mine because when I had it at a 2 mm gap it didn't sit square to the beam tube and I worried that I could damage the sleeves by pulling them back off. Beam is good so far (since 2017 and 50k-60k kilometers). Once I had a creak again and I worried that could be the reason but it was a metal bracket of the hand brake cable rubbing against something when going over speed bumps. However I would also like the pros to comment on this.
Posted 11th Aug 2020 at 20:15
jord294
It was done for a reason, and this is why I set my refubed axles as they would come from factory
Posted 12th Aug 2020 at 06:07
same here.
Posted 12th Aug 2020 at 08:36
miki4
Is there a special way you ensure the sleeves sit square?
Posted 12th Aug 2020 at 09:23
PAG306
So you're not aware of the reason it's doneRoll eyes as i don't see any reason why the sleeve's not tapped all the way down flush with the beam mount as this part just holds the seal in place which would be pressed inside the sleeve & butted upto the tube end then the correct clearance gap set between the seal lip & trailing arm
Posted 12th Aug 2020 at 12:32
I have a tool in my dealer kit that sets how deep the aleeve sits, the more critical dimension is how much of the o.d of the seal is in the sleeve.
Posted 12th Aug 2020 at 14:21
PAG306
If it's a genuine part & tube then it will be a perfect interference fit so would go on the tube squarely even if a 2mm gap was left but i've seen numerous beams with this part fitted flush & even the 'Pros' cant give any logical explanation as to why it's this way Crazy
Posted 12th Aug 2020 at 14:25
PAG306
If the seal sits flush against the end of the tube then wouldn't how far you tap the sleeve on determine how much of the seal is inside the sleeve Roll eyes surely Peugeot would make this part so it's the correct depth to tap flush with the beam mount then when the seal's installed & tapped in it sits flush with the chamfered end of the sleeve just leaving the lip to act as the watertight seal?
Posted 12th Aug 2020 at 14:40
Peugeot dont make these parts.
Posted 12th Aug 2020 at 16:35
