Author Subject: Gearbox removal
V53UBW
Hi guys, hope someone can help.
I'm trying to get the box out of my GTi6, I've managed to get all the bolts out and also got around the clutch arm problem but now I just can't get the box off the engine, the box is a good 2 inches away from the block so I've definitely got the bolts out, I've managed to get the intermediate driveshaft out with the help of a lump hammer but it just keeps hitting the inner wing.
Do I need to rotate the box?
Do I need to get the long bolt off the gearbox (the one that is used for the gearbox mounting)???
Many thanks Cool
Ian L Robinson
Posted 18th Jun 2015 at 19:03
Have you put a screwdriver through the hole in the fork shaft and turned it?
  • Posted 18th Jun 2015 at 19:15
    V53UBW
    Screwdriver through the fork shaft and turned it???????
    I don't understand
    Ian L Robinson
    Posted 18th Jun 2015 at 20:24
    To make sure the fork isn't getting stuck in the clutch bearing he means. I've started removing boxes by removing the mounting stud, makes it much easier to get it under the inner wing. Smile
    Posted 18th Jun 2015 at 20:48
    lower the engine
    Posted 18th Jun 2015 at 21:43
    V53UBW
    I shall try all suggestions again on Monday..... Any other advice would be much appreciated :-)
    Ian L Robinson
    Posted 19th Jun 2015 at 18:31
