Chaps,I have some engine parts for sale. All parts are removed from a 2003 Citroen Xsara VTS (same engine as the GTi-6), so you wont find newer or better condition!
Set of 4 x coil packs - £30 delivered
Front engine mount / ancillaries bracket - £25 delivered
Flywheel - £25 delivered
PAS pump - £30 delivered
Starter motor - £35 delivered
Alternator - £35 delivered
Coil pack cover - £15 delivered
Inlet manifold complete with TB, all support brackets, fuel rail and injectors - £60 delivered (note, this has the later style black injectors to use on a GTi6 you would need to fit some of the green injectors)
T/Stat housing - £20 delivered (this has two of the holes plugged with threaded bosses which can be removed, as the VTS only uses one sensor)
Brake servo vacuum pump with mint pipework (the small hosetail on the T piece is normally broken on these) - £25 delivered
Contact Details:rich@lynxpowerengineering.co.uk
07732 822546
rich_w
