Author Subject: Breaking 309 16v circuit car
allanallen
Sadly the time has come to break my much much loved 309. The full car is available although there are no dampers fitted at the minute, feel free to ask though! I'd be happy for someone to supply dampers and for me to get it up and running ready to go.
I would really like the shell to go first,that way the buyer can decide exactly what they want still attached. With that in mind I will be waiting for anyone to show interest for a couple of weeks before I start disassembling it.
1988 309xs Shell(with v5), full weld in cage, double diagonal door bars, harness bars, dash bar, seat mounts etc. fully glazed, bumpers, lights, gti trim etc. fabricated fuel tank with sump boxed in to meet msa regs, walbro external fuel pump with internal Teflon braided fuel lines, braided internal brake lines, poly front windows with sliders, roof vent, centre run/exit stainless exhaust, rad, clocks,no dash just a centre console, battery cables to carbon battery box in boot, QR front bumper, fia rain light,looms/fuse box, gti16 badge!!! etc etc. the shell is very solid, no crash damage although it has marks and some small areas of surface rust£1200
45k gti6 engine with conversion bits, properly unlocked ecu, re-angled mani, Bbm hose adaptor, simple alternator and tensioner set-up etc £600
16 row Oil cooler complete £100
Gripper plated LSD very little use, I can set preload to suit your requirements £550
1600 be3 box, low mileage, no issues £100
1900 gti wheels with part worn r888 £200
1900 wheels with Michelin wets, just scrubbed in £250
4 x Michelin s9 slicks £120
Rear calipers, genuine pads, brembo discs £70
309 beam, rebuilt a few years ago but done less than 1000miles. 25mm bars, 28mm arb with 306 end plates, bridgecraft neg camber arms, solid beam mounts, nylon arb bushes £550
Lifeline dumpy plumbed extinguisher £50
Ears deep dish wheel with boss £60
Stud and nut conversion £50
Bridgecraft -2.5deg front hubs, good BBJ holes, fresh bearings, for use with rose jointed tre's £140
Virtually new wishbones with recent genuine bushes £80
Virtually new 309 shafts, not cheap motor factor tat, £120
Electric pas setup, 3.2 rack, saxo pump and wiring, high and low pressure piping, reservoir etc £120
Strut brace £30
Bias adjustable pedal box with cylinders £100
Seam welded front subframe £30
309 21mm front arb with clamps and almost new bushes £70
In date black Ears harness £80
AP 4pots, brackets, bells and rotors. Ready for pads, rotors recently skimmed but they've only got another 1-2 sets of pad wear left in them. Rotors are 280x25 from memory, fit under 1900 wheels with 3mm spacers. These are the absolute bo***cks, I love these brakes! Big grin £600
Facebook
Posted 9th Jun 2015 at 14:02
And how much for the whole car dude ?
Posted 9th Jun 2015 at 12:20
orta
Loving the 309 in white! Save it chris!
CLUB BLACK RALLYE
||B8s||60-70mm drop||Black Partner Steels||P1 VTS Rack||Refurbed Beam||Hybrid ARB||VTS Torsion Bar||
Posted 9th Jun 2015 at 12:45
allanallen
If you supplied dampers and springs I'd fit them, service and get it ready to go for 4.5k
Facebook
Posted 9th Jun 2015 at 14:01
marksorrento205
Bias box please mate. Text me if and when it's available.
Posted 9th Jun 2015 at 19:37
allanallen
Spoken for sorry mark Sad
Facebook
Posted 9th Jun 2015 at 20:30
marksorrento205
Ok mate. If it falls through let me know
Posted 9th Jun 2015 at 22:00
martinh
Guess the strut brace would fit a 205?
Posted 9th Jun 2015 at 22:56
pete_rallye
What would it take to get an MOT and on the road?
Lap of the 'ring
Posted 9th Jun 2015 at 22:58
allanallen
Pete, not a massive amount really. I'd need to sort the track rod arrangement out as I was in the middle of changing it, re-fit front brakes, service and obviously fit some dampers.
Strut brace fits a 205 as far as I know yes.
Facebook
Posted 10th Jun 2015 at 07:01
allanallen
Link to some pictures from when it was first built
http://s67.photobucket.com/user/allanallen/library/309
Facebook
Posted 10th Jun 2015 at 09:03
I'd love this but sadly unless your doing. Payment plan I just can't afford it 😢
Posted 10th Jun 2015 at 10:04
RetroPug
What size are the slicks, and how much use have they had? S9 is the hard compound, correct?
Posted 10th Jun 2015 at 12:38
allanallen
Yep, s9 are hard compound. Evenly worn, dimples still visable, 2mm ish I'd say
Facebook
Posted 10th Jun 2015 at 12:54
paulgt
"1900 gti wheels with part worn r888"
Do these fit a GTi-6 with the standard brakes? and standard wheel nuts?
How much life left on the tyres and what size are they?
306 GTI 6 Track Car in the making....
Evo 5 GSR 360bhp....for now
Posted 11th Jun 2015 at 21:15
eddy_gti6
Thats a nice spec shell. Would be a nice shell for my rallye engine Hmm
Posted 11th Jun 2015 at 22:13
Cjwatson27
You will need the 205 wheel bolts has there flat seated not tapered
Posted 12th Jun 2015 at 02:17
allanallen
Yes 1900'wheels fit with gti6 brakes, you can't run any balance weights on the inside on some versions though, they're quite tight. Gti6 bolts are flat seated so as far as I'm aware they fit fine, I do recall seeing some 306 bolts with a slightly longer shank though and it was debatable wether they'd tighten down properly, easy enough to check though. Tyres are all half worn I'd say but I will get photos for you.
Cheers eddy, beauty of the 309 is the extra track and length over a 205, this is sub 900kg too and there's much more weight that could be lost Wink
Facebook
Posted 12th Jun 2015 at 07:24
paulgt
Great, thanks.
Pics when you can please, ta
Posted 12th Jun 2015 at 13:11
blandy
Any pics of the wheels/wet tyres if still available?
Posted 20th Jun 2015 at 22:18
