Author Subject: cleaning up rusty parts cheaply and effectively?
I'm wanting to tidy up some of those tired old parts!
Sure an angle grinder and attachment really does the job well
But I'm thinking about the parts that are more delicate
Like rear calipers with seals on etc
A few month ago I bought a rear beam with some free rear breaks on
I want to experiment and find the best way to clean them up again
Using things I have laying around or things easily accessible
1st ill try white vinegar
Then tomato ketchup
And I'm keen to try the electrolysis method
Has anyone else found any good methods?
Bilt hamber deox-gel I've heard is very good
But a little on the expensive side?
Posted 7th Jun 2015 at 11:36
rallyestyle
Are you not stripping the callipers before cleaning?
Just Drive It
Posted 7th Jun 2015 at 11:46
6waysforward
https://www.youtube.com/watch?v=9G976RDgEkM#action=share
Cully did a thread about this on oc. Then someone else done cullys method on a youtube vid above.
Results look good.
I just normally use a soft pad on the grinder LOL
Posted 7th Jun 2015 at 12:44
pete_rallye
Electrolysis works really well for rust removal, I've done lots of bits and even complete blocks. Bilt Hamber is an equally good rust remover, the gel is expensive but buy the Deox powder and you can mix it up quite weakly and leave it, still works, just takes longer.
Sometimes you just can't beat a drill with wire wheel attachment though!
Lap of the 'ring
Posted 7th Jun 2015 at 17:19
Ben_W
Formerly gpm
As Pete says.
Bilt Hamber deox gel or deox c solution.
Have a look on Coskevs rallye resto thread in projects. He did a pair of calipers.
Posted 7th Jun 2015 at 17:36
Ben_W
Formerly gpm
Oh, and the gel or deox c are about £12 plus post. Not expensive at all
Posted 7th Jun 2015 at 17:35
cully
personaly id use the electrolysis method even before attempting any other cleaning method because its effertless and cheep Wink
ive cleaned several parts now from hubs to steel wheels with tyres still fitted in a tank
http://306oc.co.uk/forum/showthread.php?tid=22295
Posted 7th Jun 2015 at 17:41
