I have repalced the bolts, slide pins and seals. The calipers slide easily until bolt starts to tighten.
Damage to caliper or trailing arm possible?
| Author | Subject: Rear Calipers Q |
iplay
Seasoned Pro Location: Number Wang Registered: 18 May 2006 Posts: 3,272 Status: Offline |
The driverside rear caliper stops sliding when the mounting bolts are tightened.I have repalced the bolts, slide pins and seals. The calipers slide easily until bolt starts to tighten. Damage to caliper or trailing arm possible? |
bent caliper bracket if the bolts are new and threads good________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
try it on the other side________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
iplay
welshpug! wrote: try it on the other side |
jord294
i've found that if you tighten to recommended torque they can go tight.so i just do them up to 80Nm ________________________________________ FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE. ALL AXLES BUILT USING GENUINE PEUGEOT PARTS IF I'M NOT HERE, IT ONLY MEANS ONE THING.... I'M SOMEWHERE ELSE! |
iplay
jord294 wrote: i've found that if you tighten to recommended torque they can go tight. so i just do them up to 80Nm thanks - that has been my solution for the last 2 sevices. I will swap over the brackets but they are new parts in good condition. I still think there is an underlying issue. Could the caliper itself get twisted if it was in a knock or the rear trailing arm (bolt threads?)? |
swapping brackets means pulling off the wheel bearing.never had issue with going tight with bolts done to correct torque, under torque is not a wise idea, especially on brakes!!! ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
