| Author | Subject: Cat Fitting Kit |
RetroPug
As above, anyone got a new cat fitting kit kicking around before I go to dealers/ebay?________________________________________ 61k miles Ph.1 Diablo '6 Project Thread |
rikky
I've had dealer ones when I had my S16 as getting the right one was a nightmareI've also had numerous standard eBay / ECP / Andrew Page ones, without any problems, and for about a third of the price of dealer ________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
RetroPug
Fair enough. Thanks for the info. I was under the impression that the dealerkits were universal for all larger petrol engined 306s? ________________________________________ 61k miles Ph.1 Diablo '6 Project Thread |
jord294
I can highly recommend Hoffman sports cat________________________________________ FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE. ALL AXLES BUILT USING GENUINE PEUGEOT PARTS IF I'M NOT HERE, IT ONLY MEANS ONE THING.... I'M SOMEWHERE ELSE! |
RetroPug
I only need a cat fitting kit. ![]() ________________________________________ 61k miles Ph.1 Diablo '6 Project Thread |
mik
Seasoned Pro Location: Kent Registered: 17 Feb 2011 Posts: 2,100 Status: Offline |
jord294 wrote: I can highly recommend Hoffman sports cat I know it is off-topic, but I looked at these when I was looking at cat options (ended up getting my OE one welded), and wondered if they were any good. Maybe someone could write a FAQ on cat replacement options? ________________________________________ Cherry Rallye SOLD |
RetroPug
mik wrote: jord294 wrote: I can highly recommend Hoffman sports cat I know it is off-topic, but I looked at these when I was looking at cat options (ended up getting my OE one welded), and wondered if they were any good. Maybe someone could write a FAQ on cat replacement options? That FAQ will probably become more and more useful as time goes on! I'll post up pictures of the repair I'll get done to mine. ________________________________________ 61k miles Ph.1 Diablo '6 Project Thread |
RetroPug
Bumping this, I have loads of cat fitting kit parts lying around, the problem is I have all of the bits but I'm not sure about which bolts are the correct length as I have various lengths here. I'm aware that it is the "middle length" bolt out of the kit but I can't be 100% sure which of the bolts I have would be that length.Is anyone able to give me the length of the correct bolts? Both overall length and distance from the head/taper to the thread? Any info that would help me determine whether or not I have the correct parts or I'd have to buy more bits would be very much appreciated. ________________________________________ 61k miles Ph.1 Diablo '6 Project Thread |
cully
Seasoned Pro Location: Cullompton Registered: 12 Jun 2013 Posts: 1,093 Status: Offline |
pick one you can get the nut started without compressing the springpick a short one you will be cussing pick a long one you will sound like an OC members tractor |
RetroPug
cully wrote: pick one you can get the nut started without compressing the spring pick a short one you will be cussing pick a long one you will sound like an OC members tractor I did the first one, but it didn't compress enough so maybe it is long. I have acess to a ramp but I don't want to obtain that access, drive the car a long way without much of an exhaust (my cat outlet pipe has now snapped again), and then find I don't have the correct parts. I have bolts which are shorter than the ones I used but if I used the long ones and my other ones are shorter, I don't know whether or not they are the medium, correct ones or the ones which are too short. ________________________________________ 61k miles Ph.1 Diablo '6 Project Thread |
RetroPug
Bump, anyone able to tell me the correct length to use?________________________________________ 61k miles Ph.1 Diablo '6 Project Thread |
scotzman
Seasoned Pro Location: Dundee Registered: 24 Jun 2011 Posts: 1,408 Status: Offline |
I could measure the length of the two sizes I didn't use.________________________________________ '90 1.6 205 GTi, '98 306 GTi-6 |
davidmartin
Seasoned Pro Location: Beautifull Ystalyfera Registered: 21 Oct 2006 Posts: 3,316 Status: Offline |
RetroPug wrote: Bump, anyone able to tell me the correct length to use? Done the sigma not that long ago, and honestly I think everything is so distorted through the heat, it's trial and error, couple of washers on the old kit and a £4 gsf ring sorted it for me. ________________________________________ pet hate, the cat |
scotzman
The two sizes I didn't use were, complete length 65.5mm and 72mm.No idea if I used the correct pair but they went on easy enough and it doesn't leak. ________________________________________ '90 1.6 205 GTi, '98 306 GTi-6 |
RetroPug
scotzman wrote: The two sizes I didn't use were, complete length 65.5mm and 72mm. No idea if I used the correct pair but they went on easy enough and it doesn't leak. Thank you, much appreciated. I'll see what I've got! ________________________________________ 61k miles Ph.1 Diablo '6 Project Thread |
RetroPug
Those are the two sizes I have spare in a box. I do not know what size is currently on the car and whether or not it is correct. Anyone else able to help?________________________________________ 61k miles Ph.1 Diablo '6 Project Thread |
cully
il add a bit more confusion!just had a rummage in my bolt box, i have 3 different length bolts all used, i also have 3 different length compression springs too! |
RetroPug
Brilliant! Yeah I think I have various springs as well, perhaps I need the same bolt but a longer spring then.A while ago I bought multiple kits and struggled to make any of them fit correctly. ________________________________________ 61k miles Ph.1 Diablo '6 Project Thread |
I've always found that when its a struggle to get the nut on for the first thread or two the setup is then pretty good at keeping itself sealed. Probably more awkward for me though as i do it laying on my back under the car making access much harder. ![]() ________________________________________ Goldie the track car. |
i just bought an o.e kit when i fitted the engine 6 years ago and its still on now!________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
cully
cat-manifold fixing kit 179875 £14.99 retail from pug |
