Author Subject: Engine rebuild
Davidson600
I have just bought a completely standard Gti6 with 84000 miles (seem to be legitimate miles) I am thinking about spending some money rebuilding the engine and wondered if anyone can recommend the best 306 specialist in the UK to aid in this, possibly even carry out the work if it won't be too expensive. also the gear box is a bit whiney, so might just bite the bullet with that and the clutch. where is the best place to get a reconditioned gear box with mine as a part ex?
thanks for your help in advance Smile
Posted 8th May 2015 at 11:56
rhyds
if its only got 8400 geniune miles on it, i wouldn't bother with a re build personally at this moment in time. i've had 4-5 engines in various gti6's all with 130k+ on the clock and they go better than the low mileage (75k ish) that's currently in my road 6
my road 6 has got a crunchy 3rd gear as well. i have know the car history over the last 12 years and it had the crunch back then as well. it has been hammered since and the crunch has got no worse
Posted 8th May 2015 at 12:56
Welcome to the club! Wave
As said, there isn't really much point in rebuilding yours just yet - it does appear that the higher milers seem to be 'looser' and pull very well.
If you want to go ahead with this, seeing as you're in Scotland you could try Ecosse. However, be warned they are expensive. You may be able to get a deal on a gearbox from them though.
Stan.
Posted 8th May 2015 at 13:19
Davidson600
There is a whine coming from the engine/ gearbox, not sure what it could be to be honest. Im not a mechanic my skills and experience is limited to replacing parts i.e. brakes and exhaust. never really been in a position of diagnosing a fault. was hoping to take it to a specialist for a full check over to see if there are any problems with the car at all.
Posted 8th May 2015 at 15:05
ryangti6
In my experience a whine from the gearbox is cured by an oil service.
As others have said don't worry about a rebuild, loads are on double that mileage and still going strong.
Ryan
Posted 8th May 2015 at 15:48
mocinim
Had mine rebuilt in jan by pug1off attention to detail with putting back loom and other bits wasn't great but with regards to the engine went in at 152k miles was abit noisy all round smokey etc came out very sweet pulls like a train quiet and smooth not a bad job after care was also good
if you get a rebuild remember to run it in slowly treat it like its had a transplant will need at least 500miles to seat before you open it up
But as the others have said it is pricey
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 8th May 2015 at 16:24
honestly3k
Really dont get this notion you see these days of 'oh my car has covered 70k miles, it must need a rebuild'?!
My bosses were talking the other week, one says to the other 'when should you replace your car', she replies 'oh after about 5 years I guess'.
I'm sitting there thinking what the f**k?! Run a car for as long as it lasts, if its a good design and is serviced regularly they should run for big miles.
I got my GTI6 on 60k and in three years put over 100k on it, it got rear ended on 166k and was still eating up the miles. Very healthy engine that loved to be ragged.
If it aint broke, i wouldnt fix it. Not worth it!
Posted 8th May 2015 at 17:06
miles
First problem with these engine's is bore wear, so it's either oversize and new pistons etc or sleeve the bore back to 86mm, But as we know each engine is different, I'm sure I hold the record of 285,000 before the HG failed and that engine went and performed better than most with 3/4 of the mileage on them
Box's should last at least 150k, unless someone's used the wrong oil
www.pugracing.com
Posted 8th May 2015 at 23:01
