Anyone know if running a 4bar FPR in the standard fuel rail will make any difference to normal running ? I will be installing a worked Longmans head
| Author | Subject: Running a 4 bar FPR |
Hi All Anyone know if running a 4bar FPR in the standard fuel rail will make any difference to normal running ? I will be installing a worked Longmans head Cheers Chris |
it will overfuel.leave the 3 bar one in. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
We used to run 3.5 bar fpr with moded engines and they worked a treat ??? |
jeffers
Forum AdminLocation: Leeds Registered: 14 Dec 2003 Posts: 3,702 Status: Offline |
As said Chris, google it, it will screw the map up and over fuel. Unless your having it mapped on completion I'd leave it.________________________________________ Team Running Engine again!Team Negative Camber! My Budget track engine build thread! Now appearing at a Trackday near you!! |
Ok so go with a 3 bar ? |
I was intending to get the old girl mapped down the line though once I've sorted some cams and got the head on etc ? |
I run 3 bar at over 200.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
