displaying posts 51 to 60 of 60
Pages (3): 1 2 [3]
Author Subject: Peugeot Sport Decat System to fit
daver6
Post #51
Day666 wrote:
daver6 wrote:
I've used powerflex mounts and still melted them
How did you get round yours ?
Still haven't solved it, but I'm out for surgery now, so the car will have to wait
Wishbone Polybushes available
Posted 2nd May 2015 at 08:02
daver6
Post #52
Post #53
Mine just uses standard rubber mounts with no issue.
Posted 2nd May 2015 at 08:08
Post #54
I've caused a problem I wouldn't of had by Wrapping every part of my exhaust Adam ...but forgot to wrap the hanger so all heat encased heads there & bingo melted rubber ....I needed to wrap it because of the Sachellshift & all the heat shields being removed !!!
Easy fix got some heat tube to go round the hanger & just drilling one end of the powerflex out bigger Sorted Thumbs up
Posted 2nd May 2015 at 08:22
RetroPug
Post #55
Can you put some heat reflective materials on the underside of the tunnel?
Posted 2nd May 2015 at 09:21
eddy_gti6
Post #56
I had a full heatwrapped exhaust on my astor and never melted any of my standard rubber mounts. I had a heatwrapped manifold, decat and straight through middle section. Try get hold of a set of audi exhaust hangers, i had some s3 ones on my nile 6 and they were more solid than the pug ones too
Posted 2nd May 2015 at 12:02
Post #57
Don't forget.... EVEN both my boxes are wrapped in ceramic 3 layer Zirotec basically Everything is & I could stick something in the tunnel but how would you keep it up there ?
Posted 2nd May 2015 at 14:18
eddy_gti6
Post #58
What do you mean stick something in the tunnel?
Posted 2nd May 2015 at 14:23
Post #59
I've got to take the heat shields away from gearbox forward To fit my Satchellshift Eddy & any exhaust makes the tunnel super hot ...but Stainless as you know makes it much hotter as it holds the heat much more !
So some people are thinking about sticking Zircotec self adhesive flex able ceramic sheeting down the tunnel from the box forward Eddy Thumbs up
Problem is its half moon & that sticky will need clean smooth service to work ?
Posted 2nd May 2015 at 17:03
Post #60
Got my Exhaust sorted finally by Infinity Exhausts Codrington Bristol ....
Did a top job...
Got x2 joints sorted & new hangers lined up & welded on with Red PowerFlex mounts Thumbs up
Posted 17th May 2015 at 14:11
Pages (3): 1 2 [3]
