| Author | Subject: Satchshift brief fitting guide |
Chr1sch
Seasoned Pro Location: Worcester Registered: 02 Aug 2014 Posts: 1,025 Status: Offline |
ffs this is getting silly time wise, although i guess i'd rather quality was top notch than rushed... |
pugheaven
Seasoned Pro Location: Fareham Registered: 17 Dec 2006 Posts: 4,602 Status: Offline |
Ring up Colin and get it delivered directly from them rather than them send it to kam and then them send it to you |
pugheaven wrote: Ring up Colin and get it delivered directly from them rather than them send it to kam and then them send it to you Tried that ? Looks like Colin is bit to busy at mo ? Must admit with a winning reputation like he has a handful of Sachshifts is the least of his worries Fingers crossed |
measuring down along the bulkhead to the mounting bolt for the boot bracket would be easiest, will see if I can do it.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
pugheaven
The most accurate way of doing it would be to fit your lower linkage bar and then measure up, once you have drilled a 30mm hole fit the top linkage bar and slide the boot up to the bulk head, Mark around the out side of it and then just open the hole up but leaving a few mm for the thickness of the boot tube |
pugheaven wrote: The most accurate way of doing it would be to fit your lower linkage bar and then measure up, once you have drilled a 30mm hole fit the top linkage bar and slide the boot up to the bulk head, Mark around the out side of it and then just open the hole up but leaving a few mm for the thickness of the boot tube I'm going to try that if mine ever turns up ? I was on the first Batch but sadly just missed out |
fitting the lower bar isnt any help, it gets in the way!!what I need is the dimension I asked for measure down the bulkhead from the seam or upper heatshield bolt to the centre of the hole, or the bolt holding the bracket for the boot if that is fitted.measuring in a vertical line wont help. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
never mind, I can't get a drill anywhere near!!!________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Chr1sch
This is beginning to sound like a bloody nightmare |
Post #35
welshpug! wrote: never mind, I can't get a drill anywhere near!!! Mei if you can't do it what chance have we ??? I got a 90 degree drill would that help or not ? So are you thinking Dash out Mei !!!! Mine won't be here for two wks as CS flat out & didn't expect the 306 ones to be so popular |
Post #36
I haven't got one of those :/you overestimate my facilities!! dash out wont help, no reference point to make the hole. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
jeffers
Forum AdminLocation: Leeds Registered: 14 Dec 2003 Posts: 3,702 Status: Offline |
Post #37
welshpug! wrote: I haven't got one of those :/ you overestimate my facilities!! dash out wont help, no reference point to make the hole. You need one of these Mei..... https://www.machinemart.co.uk/shop/product/details/rad-1-right-angle-drill-attachment ________________________________________ Team Running Engine again!Team Negative Camber! My Budget track engine build thread! Now appearing at a Trackday near you!! |
Post #38
welshpug! wrote: I haven't got one of those :/ you overestimate my facilities!! dash out wont help, no reference point to make the hole. Mei ...How the Hell did Ollie do his then ? He did say it would be a lot harder with the dash in for some reason ??? Come on Ollie spill some more beans !!!! Or we are all going to end up with a flint stone floor |
pugheaven
Post #39
Sorry I have only just seen this, I used the template.....I'll measure that for you today Mei but I honestly think having the lower bar in and using that as a datum is the best bet! If I measure the bolt that holds the boot it won't really help you as mine might be wrong... It's already melted the boot and plastic collar that the bar goes through and iv only done 40 miles and that's only taking it to around 4k so the exhaust isn't getting that hot I'll give you those measurements but please don't blame me if yours goes wrong! Once you have drilled a hole kinda in the centre I still think the dash out is the only way to go as access from underneath is limited unless you take the manifold and subframe off! |
superchargedblack1997gti6
Post #40
Ha ha sounds like it's going to melt everyone's then as you're manifold is ceramic coated mate most people is going to get creamed, may have to invest in a really good bit of heat shielding for the boot and collar ![]() ________________________________________ Super high boost Completed, destroyer of gearboxes and 160mph club |
pugheaven
Post #41
Mei I keep looking at your upper heat shield lower bolt and it looks completely different to mine... I didn't even have those holes as mine was an s16 which didn't have manifold heat shields, I had to drill my own holes and fit riv nuts, I also have a metal heat shield that had holes in the wrong place for a 6 shell (luckily for me it didn't matter) |
pugheaven
Post #42
Ross I cut a good 15mm off the boot tube and cut half of the boot down too.... As discussed with rich I think either having no boot or a big grommet that sits inside the tube is the only way to go! Trust me there is no room for a heat shield |
Post #43
Ollie I'm talking about a bit of exhaust heat wrap lock wired in place? Should give the collar a better chance of surviving?________________________________________ Super high boost Completed, destroyer of gearboxes and 160mph club |
pugheaven
Post #44
I guess so but it's the flange that connects the manifold and down pipe that it's close to so you would have to do it over the join and mounting bolts... Worth a try I guess |
pugheaven
Post #45
Trust me it's worth the effort, I was going to give up at one point but the gear change is so precise and accurate it's awesome I might get rid of the boot and collar and fit a bit of rubber sheet with a hole in the middle for the bar to pass through and have it on the inside of the car or under the mounting boot on the engine bulk head side |
Post #46
pugheaven wrote: Trust me it's worth the effort, I was going to give up at one point but the gear change is so precise and accurate it's awesome I might get rid of the boot and collar and fit a bit of rubber sheet with a hole in the middle for the bar to pass through and have it on the inside of the car or under the mounting boot on the engine bulk head side Problem is Ollie it's all modifying & I'm good at doing that but you guys are struggling ....ok I'll give it a go ...But I know I'm going to regret this So your really saying its that good your happy to put up with the problems until you think of a way around it ??? Bloody hell it must be good !!! |
pugheaven
Post #47
It's only a rubber boot to stop s**t getting into the car, no big deal! I thought I was making a meal out of fitting it but now Mei is struggling I don't feel so bad lol |
pugheaven
Post #48
I'll sort the boot problem out soon and send everyone some of the stuff I plan to use to resolve the issue |
Post #49
pugheaven wrote: It's only a rubber boot to stop s**t getting into the car, no big deal! I thought I was making a meal out of fitting it but now Mei is struggling I don't feel so bad lol That's exactly what I was thinking ....if Mei is struggling blimey what chance have we got I've even covered my Exhaust box with this crazy price Stuff from Merlin at Combe .... Day666 has attached the following image: |
Post #50
This stuff Stainless steel cable tied & stainless lock wired on with Exhaust wrap because you said the Exhaust shields have to come off from gearstick forward ?Day666 has attached the following image: |
