Author Subject: Can you find a paint code from a registration?
martinh
I've seen a silver 1.4 306 being broken but want to confirm the paint code before I buy the front bumper off it. Registration is X347 OBD.
Does service box allow a registration search or just chassis number? Have only used it for part numbers off a chassis number so don't know if you can find paint codes etc on there?
Posted 29th Mar 2015 at 20:25
cully
service box will show what the car left the factory fitted with including paint code wheels ect ect
but you will need the VIN to find this on service box
Posted 29th Mar 2015 at 20:59
davidmartin
The VIN is VF37AKFWF33180267
pet hate, the cat
Posted 29th Mar 2015 at 21:05
cully
306 (RESTYLING) 5 DOOR SALOON 1.4i 75 (TU3JP) Manual gearbox 5
Vehicle characteristics
Vehicle family 306 (RESTYLING)
Build code 08770 81 2 0091
Warranty Start Date 10/01/2001
BER e2*98/14*0240*00
General information
PRODUCT TYPE CAR
COMMERCIAL MARQUE/COMPONENT TYPE PEUGEOT
VEHICLE FAMILY 306 (RESTYLING)
SILHOUETTE 5 DOOR SALOON
TRIM LEVEL LEVEL 2C
ENGINE INJECTION TU3JP
TRANSMISSION BVM5
PAINT TYPE METALLIC PAINTWORK
INTERIOR TRIM TYPE CANNELLE VELVET "LJ"
UPHOLSTERY COLOUR "FY"
GEARBOX (CHARACTERISTICS) UP-RATED BVM/MA (A/Cool
ENGINE (TYPE) TU/TUD
OTHER BADGE, " MISC. " WITHOUT FULLER BADGE
BADGE LX
TRIM LEVEL LEVEL 2C
STEERING UNVARIABLE POWER STEERING
SPEEDOMETER DRIVE TACHO TORQUE 21X18
Fuel supply-Engine
INJECTION ASSOCIATED VARIANT MOUNTING SAGEM
FUEL FILLER CAP FUEL CAP WITH LOCK
DIESEL FILTER WATER DETECTOR WITHOUT DIESEL FILTER WATER DETECTOR
CYLINDER BLOCK (MATERIAL) CRANKCASE ALUMINIUM
FUEL LEAD FREE PETROL
EMISSIONS STANDARD (ENGINE) EEC 2000 DEPOLL (ENGINE)
PRE-FILTER ASSEMBLY WITHOUT PRE-FILTER
CATALYTIC CONVERTER 3 PARTS CATALYST
OIL COOLER WITHOUT OIL-WATER DISTR CHAMB
ENGINE TEMP. NOZZLE ENGINE WATER TEMPERATURE BOX
CRANKCASE GAS CIRCUIT HEATING W/O HEATER CASING GAS CIRCUIT
FUEL SUPPLY CUTOFF FUEL FEED CUT-OFF
POWER VARIATION (ENGINE) STANDARD POWER
REGULATION 70/221 (FUEL LEAKS) WITH ANTI-RETURN VALVE
RHEOSTAT RHEOSTAT
VEHICLE TECHNICAL DEPOLLUTION L4 VEHICLE TECHNICAL DEPOLLUTION
FAN 1 FAN , 2 RATES
FUEL VAPOUR RETRIEVAL CONTROLLED PETROL VAPOUR RECUPERATION
Gearbox Transmission
TRANSMISSION BVM5
FINAL DRIVE RATIO REAR AXLE HYPOID GEARSET 14 X 60
WHEEL STYLE BLACK OPTIMIZED WHEEL
CLUTCH CABLE CLUTCH TAKING UP OF PLAY
GEARBOX SAFETY LOCK W/O G/BOX SECURITY LOCKING
DIFFERENTIAL (GEARBOX) STD GEARBOX DIFF
TYRE (SIZE, TYPE) 185X65X14 T TYRES
WHEELS FITTED 5,5" RIM ROAD WHEELS
WHEEL (TYPE) STEEL WHEELS
GEARBOX TYPE MA
Suspension-Steering-Brakes
ABS WITH ABS BRAKES
REAR ANTI-ROLL BAR ANTI-ROLL BAR DIAM 18
ANTI-THEFT DEVICE STANDARD ANTI-THEFT
FRONT ANTI-ROLL BAR FRONT ANTI-ROLL BAR DIAM 17
TRACTION CONTROL WITHOUT ANTISLIPPING
SERVICE BRAKE ELECTRONIC BRAKEFORCE DISTRIBUTION
BRAKE TYPE VENTILATED FRONT DISCS/REAR DRUMS
SUSPENSION NORMAL SUSPENSION
BRAKE ASSOCIATED VARIANT ADDITIONAL ABS5 BOSCH
Body fittings
TOWBAR WITHOUT TOWBAR
HORNS HORN STANDARD
AERIAL SHORT ROOF AERIAL
WIPER ARM FRONT BLADE WITHOUT DEFLECTOR
HOOD WITHOUT HOOD
REAR SPOILER ASSEMBLY WITHOUT REAR SPOILER
SIDE MOULDINGS (DIMENSION) LATERAL PROTECTORS L=40 + SIDE SILL
WHEEL EMBELLISHER (STYLE) SONATE STYLE 6 HOLES 14 INCHES
ADDITIONAL SHIELD (UNDER ENGINE) W/O ENGINE UNDERSHELDING
HARD TOP WITHOUT HARD-TOP
EXHAUST TAILPIPE TRIM WITH INTEGRATED EXHAUST TAIL PIPE TRIM
ENGINE BAY SOUNDPROOFING WITHOUT SOUND-PROOFING
WINDSCREEN WIPER FRONT WIPER BLADE WITH RAIN SENSOR
REAR SCREEN WIPER REAR SCREEN WIPER
HEADLAMP WIPER W/O HEADLAMP WIPER
FRONT PANEL BLANK BUMPER GRILLE NOT CLOSED
BUMPER BODY COLOUR FRONT/REAR SPORT BUMPER SINCE MOD2000
LUGGAGE RACK WITHOUT ROOF BARS
FRONT FOGLAMP FRONT FOG LIGHTS
SPECIAL HEADLAMP (DOUBLE OPTIC) DOUBLE OPTIC LAMPS
EXTERIOR REAR VIEW MIRROR (DRIVER SIDE) HT EXT RRVW MIRROR EL INT CONTR
EXTERIOR REAR VIEW MIRROR (PASSENGER SIDE) OUTSIDE PASS RRVIEW MIRROR HEATED ELEC CNTRL
SPARE WHEEL STEEL WHEEL + STANDARD TYRE
EXTERIOR ACCESSORIES BODY COLOURED DOOR HANDLES + MIRRORS
SPARE WHEEL MOUNTING STANDARD SPARE-WHEEL CARRIER
REAR SCREEN WASH REAR SCREEN WASH
SUN ROOF FIXED ROOF
HOOD COLOUR WITHOUT HOOD
BUMPER TRIM BODY COLOUR BUMPER STRIP
REAR WINDOW (TYPE) REAR GLASS HEATED
GLASS (APPEARANCE) TINTED
REAR QUARTER WINDOW (TYPE) WITHOUT REAR QUARTER GLASS
WINDOW (TYPE) ATHERMAL WINDSCREEN
Interior fittings
SIDE ARMREST (TYPE) LATERAL ARMREST INJECTED FR/RR
ANTI-THEFT ALARM WITHOUT THEFT PROTECTION ALARM
REAR HEAD RESTRAINT JOINTED REAR HEADREST
FRONT HEAD RESTRAINT JOINTED FRONT HEADREST
REAR SEAT SEPARATE FOLD BACK BENCH SEAT
REAR SEAT ARMREST WITHOUT REAR ARMREST
LOAD FLOOR MOULDING WITHOUT LOAD FLOOR STRIP
LUGGAGE COVER WITH LUGGAGE COVER
REAR SEATBELT RR RETRACT BELT+STATIC LAP
FRONT SEATBELT PYROTECHNIC SEAT BELT WITHOUT ALARM
CLIMATE (AMBIENT TEMP) TEMPERATE COUNTRIES
SPEED GRADUATIONS GRADUATION MPH
GRAB HANDLES FR + RR HANDLES WITH HOOKS
TACHOMETER REV COUNTER WITH NEEDLE
CONSOLE LONG CONSOLE WITH AIR DUCT
DRIVING POSITION RIGHT HAND DRIVE
LOAD SPACE LIGHTING WITHOUT ARRANGING LIGHTING
BOOT AND LOAD SPACE LIGHTING AUTO BOOT LIGHT OR LOAD VOL SWITCH
DASHBOARD EQUIPMENT THERMOSLEEVED DASHBOARD + PAINTED PANEL
MISC. INT. LAMPS MAP READING LAMP
INSTRUMENT PANEL (CHARACTERISTICS) 4 DIALS WITH LUMINOUS NEEDLES
TACHOMETER (SIGNAL CONNECTION) REV COUNTER CALC
CHILD SEAT ANCHORING POINTS WITHOUT CHILD SEAT MOUNTING
LOUDSPEAKER 4 SPEAKERS (2 COAX/FT DOORS+2 BICONICAL/RR SHELF)
RADIO CONTROLS REMOTE RADIO CONTROL
SCREENING (BLIND, SIDE SUNBLIND, SUNROOF) WITHOUT REAR BLIND
FRONT PASSENGER SEAT HEIGHT CONTROL WITHOUT FRONT PASSENGER SEAT HEIGHT ADJUSTMENT
DRIVER SEAT CONTROL DRIVERS FRT SEAT MANUAL CNTROL
FRONT PASSENGER SEAT CONTROL PASSENGER FRT SEAT MANUAL CNTR
DRIVER SEAT ADJUSTMENT INCLIN DRIVERS SEAT SQUAB FIXED LAT+LUMBAR BEARING
FRONT PASSENGER SEAT ADJUSTMENT INCLIN PASSENG SEAT SQUAB FIXED LAT+LUMBAR BEARING
ROOF CONSOLE LONG ROOF CONSOLE
CHOKE CONTROL WITHOUT CHOKE FLAP CONTROL
EXTERIOR TEMP. INDICATOR EXT TEMP INDICATOR
COMPACT DISC COMPACT-DISC PRE-EQUIPMENT
REAR WINDOW LIFT MAN CTRL REAR WINDOW LIFTER
DRIVER’S WINDOW LIFT SEQUENTIAL DRIVER’S ELECTRIC WINDOW
PASSENGER’S WINDOW LIFT ELEC CNTRL PASS FRONT WINDOW LIFTER
CLOCK NUMERIC CLOCK
COURTESY MIRROR DRIVER+PASSENGER WITHOUT LIGHTING
OIL GAUGE W/O OIL LEVEL INDICATOR
HEATING ELEMENT NON HEATED SEAT
FRONT LATERAL AIRBAG LATERAL AIR BAG
PASSENGER AIRBAG PASSENGER AIRBAG
EQUIPMENT PACK W/O EQUIPMENT PACK
AIRBAG DEACTIVATION MANUAL AIRBAG DEACTIVATION
COURTESY LAMP FRONT DOORS CONT - FR+RE INTERIOR LAMP
HEADLAMP HEIGHT ADJUSTER REMOTE MANUAL HEADLAMP ADJUSTMENT
FRONT SEAT GUARD WITHOUT SEPARATION GRILLE
RADIO RECEIVER "RD1" RDS COMPACT DISC AUDIO SYSTEM
REFRIGERATION REGULAR AIR CONDITIONNING
CRUISE CONTROL WITHOUT SPEED CONTROL
DRIVER’S SEAT HEIGHT CONTROL PARALLEL DRV HEIGHT ADJ
RHEOSTAT RHEOSTAT
CARPET COVER W/O CARPETMAT
DRIVER AIRBAG DRIVERS AIR BAG
CARPET DILOURS CARPET F330
WEAR INDICATOR W/O BRAKE WEAR WARNING LIGHT
INTERIOR PROTECTION W/O PROTECTING NET
SWITCH ELECTRONIC ANTI-THEFT KEY
COOLANT LEVEL WARNING LAMP NO WATER LEVEL WARNING
TRIM ADAPTATION WITHOUT MOULDING ADAPTATION
LOCKING CONTROL CENTRAL DEAD LOCKING
STEERING WHEEL RUBBER STEERING WHEEL 4 BRANCH
STORAGE SPACE LOCKS LOCKING GLOVEBOX
FAN 1 FAN , 2 RATES
Electrical
ALTERNATOR ALTERNATOR 70 AMP
HORNS HORN STANDARD
BATTERY BATTERY L1 250
STARTER MOTOR STARTER MOTOR CL 2
SPECIAL LIGHTING WITHOUT PARTICULAR LIGHT
Component manufacturers
Miscellaneous
SPECIAL SPECIFICATION STANDARD
ATMOSPHERIC CONDITIONS NORMAL ATMOSPHERE
SIDE IMPACTS DOOR WITHOUT REINFORCEMENT
SET OF KEYS 2 HF PLIP KEYS + 1 SINGLE MAIN KEY
DOOR SEAL SEAL DIRT EXCLUDER
SURFACE CONDITIONS GOOD TERRAIN
SPEED MONITORING WITHOUT SPEED CHECK
SLAVE CONTROL UNIT 23 FUSES BOX
EMERGENCY WARNING TRIANGLE WITHOUT WARNING TRIANGLE
Posted 29th Mar 2015 at 21:12
basically, NOPE.
Posted 29th Mar 2015 at 21:25
cully
yup i thought it did
PAINT TYPE METALLIC PAINTWORK! not a lot of good for you that
Posted 29th Mar 2015 at 21:34
General information
PRODUCT TYPE CAR
TRIM LEVEL LEVEL 2C
TRANSMISSION BVM5
BADGE LX
TRIM LEVEL LEVEL 2C
Fuel supply-Engine
RHEOSTAT RHEOSTAT
FAN 1 FAN , 2 RATES
TRANSMISSION BVM5
GEARBOX TYPE MA
ABS WITH ABS BRAKES
Body fittings
HORNS HORN STANDARD
HOOD WITHOUT HOOD
SUN ROOF FIXED ROOF
Interior fittings
CLOCK NUMERIC CLOCK
RHEOSTAT RHEOSTAT
FAN 1 FAN , 2 RATES
Electrical
HORNS HORN STANDARD
Miscellaneous
I agree
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 29th Mar 2015 at 22:25
General information
PRODUCT TYPE CAR
TRIM LEVEL LEVEL 2C
TRANSMISSION BVM5
BADGE LX
TRIM LEVEL LEVEL 2C
Fuel supply-Engine
RHEOSTAT RHEOSTAT
FAN 1 FAN , 2 RATES
TRANSMISSION BVM5
GEARBOX TYPE MA
ABS WITH ABS BRAKES
Body fittings
HORNS HORN STANDARD
HOOD WITHOUT HOOD
SUN ROOF FIXED ROOF
Interior fittings
CLOCK NUMERIC CLOCK
RHEOSTAT RHEOSTAT
FAN 1 FAN , 2 RATES
Electrical
HORNS HORN STANDARD
Miscellaneous
I agree
Posted 29th Mar 2015 at 22:26
cully
bit early for a double bump normal takes at-least 4 years from yourself Razz
Posted 29th Mar 2015 at 22:51
ian7675
Techno Viking
I've been into a dealer before and they found the paint code from the registration.
Less than 24 hours to go!
Posted 30th Mar 2015 at 15:21
Eddleston
Open the bonnet, go to the passenger side, look in the cavity just under the windscreen. There might be a little square with a paint code on it. 3 Letters.
That's where mine is.
Hopefully the person can do that for you
Posted 2nd Apr 2015 at 20:05
I can't even remember posting that
Posted 2nd Apr 2015 at 21:44
