Author Subject: Hub differences
Ben_W
Formerly gpm
Guys,
I know there appear to be 2 sizes of hub, relating to the ball joints.
Other than phase, is there anything else that defines which car has which? From everything I've read, only the phase 3 has the 18mm versions. Id assume that my Rallye has the 16mm hubs?
Posted 9th Mar 2015 at 22:08
demondriverdan
My 3 Rallyes all have 18mm hubs, likely yours is the same
Rallye Race Car
Posted 9th Mar 2015 at 22:20
Ben_W
Formerly gpm
Thanks Dan. Assume the ABS sensors are just as much a PITA to remove as the rears?
Posted 9th Mar 2015 at 22:30
They will break so either leave them I or get new ones Thumbs up
T reg was the change over year roughly Thumbs up
Posted 9th Mar 2015 at 22:32
demondriverdan
Mine broke when I took them out, so I'd expect them to break for you as well! Smile
Rallye Race Car
Posted 9th Mar 2015 at 22:33
Ben_W
Formerly gpm
Assume news one are silly expensive??
Posted 9th Mar 2015 at 22:38
Rich E Forum Admin
Once you've got the driveshaft out give the ABS sensors a good soak with WD40 or similar (on both sides) and then tap them out from the inside.
Posted 9th Mar 2015 at 22:43
Ben_W
Formerly gpm
Thanks Rich. Does that method damage them?
Rich E Forum Admin
Shouldn't do.
Best way I've found is to use a socket just big enough for the protruding part of the sensor to sit inside it but still sits on top of the sensor body.
Then just pop in an extension bar and tap out with a hammer.
Posted 9th Mar 2015 at 22:46
Ben_W
Formerly gpm
Makes sense.
Cool, thanks bud. Looking for another set of hubs to clean up. first thing they'll get is a Deox C bath, hence the need to remove the sensors...
Posted 9th Mar 2015 at 22:58
