Author Subject: hazards flashing when car is locked but no siren?
Mossy1985
As title says really guys. I will lock my car as normal and the indicators flash to confirm.the car is locked and alarm/immobiliser is active. Then sometimes (and its only sometimes not always) the indicators will be flashing but the alarm siten isnt sounding? Now im wondering if the siren has been cut or even removed possibly but i have owned the car since oct and have never noticed this before until a few days ago. Im wondering if this is something people have come across before? My car is a phase 3 6, centtal locki g works fine and the red light on the dash flashes when the car is locked.
Posted 4th Mar 2015 at 19:18
Siren is knackered.
  • Posted 4th Mar 2015 at 19:19
    Mossy1985
    Any more info dan lol is the hazards flashing by themselves a telltale that the siren is knackered or are you saying my alarm is going off and the siren is knackered? The last thing i need is a problem with my alarm
    Posted 4th Mar 2015 at 19:22
    unplug the siren for confirmation but it'll most likely be fubar and have water in it
    Posted 4th Mar 2015 at 19:29
    Ultrasonics are shot and so is the alarm siren
    Posted 4th Mar 2015 at 19:43
    GTi6-PJL
    Mine has done this since I bought it back in 2013 - funniest moment was when the hazards went off while it was on the back of the low loader on the M6. Quick plip to unlock the damn thing sorted it. If you lock it with the key in the lock the alarm isn't activated, so I'd do that for now to save flattening the battery.
    To be honest the alarm siren is in a godawful location (behind the passenger fog light) - if the underside bumper guard is missing on the passenger side it'll get full of water & road grime.
    Apparently a siren from a 106 fits (with the added bonus of also being in better condition - IIRC I read that on here?) but I can't personally verify it.
    2000 W Phase 3 Moonstone.
    Posted 4th Mar 2015 at 19:50
    Mossy1985
    Ok guys so my siren is fubar. I replace it and all becomes good again? Or i replace it and then my alarm goes off?
    Posted 4th Mar 2015 at 20:26
    cully
    206 sirens fit, although there are two different types fitted to the 206, but only one is the same size, shape and part number, they are behind the battery on the bulkhead Wink
    Posted 4th Mar 2015 at 20:27
    Mossy1985
    Well there are enough people breaking gtis so surely i should be able to find a siren that works? I will be removing the front bumper for access when i will be fitting the engine so could replace it then. Will a new siren stop my hazzards flashing? Or am.i going to have issues with the ultrasonics inside the car as well?
    Posted 4th Mar 2015 at 20:38
    scotzman
    As said above get one from an early 206, they don't sit in the wheel arch so tend to last a bit longer.
    Posted 4th Mar 2015 at 20:47
    I agree, ultrasonics are knacker'd so alarms getting set off but siren isn't going off because it's also knackered.
    Get some phase 2 ultrasonics and solder them in to the loom, easy done.
    As for the siren, find a working used one or splash out over £100 at peugeot for new if they still do them
    andrew315rawson@live.co.uk
    Moonstone phase 7 gti6
    Posted 4th Mar 2015 at 20:55
    cully
    who knows ! it is french electrics we are talking about here. can be a little like Russian roulette LOL
    Posted 4th Mar 2015 at 20:56
    Mossy1985
    Ok guys thanks alot for the info most appreciated. I will try to locate a 206 siren and a set of ultra sonics. Any reason why i need phase 2 ultrasonics though?
    Posted 4th Mar 2015 at 21:20
    Just because Phase 2 is cheaper if your buying new, as far as I'm aware the sensors are identical, I think the phase 3 just have a longer loom on them.
    I'd fix the ultrasonics before you fit the siren Smile
    Posted 4th Mar 2015 at 21:25
    Mossy1985
    Ok mate will give it a bash cheers
    Posted 4th Mar 2015 at 21:27
    Ultrasonics are longer available - you can however disconnect them to sort the problem
    Posted 4th Mar 2015 at 21:33
