Author Subject: Smoking exhaust tunnel
Puggitt
I started my project car the other day and left it there idling to charge the battery a little, after a little while the exhaust tunnel started smoking so I had a look and it was coming from under the handbrake.
It looks as though the tunnel was melting the wire insulation and the little scratch guard under the handbrake mechanism. It was folking hot!!!
The exhaust system it the standard tubing but it's got a huge mid box and a fairly free flowing back box. Interior is stripped too.
So basically I'm wondering, does the standard exhaust system heat the tunnel? Has this happened to anyone else? Or is my exhaust mounted too high up in the tunnel?
Posted 20th Feb 2015 at 19:54
There should be heat shields above the mid box area from pretty much the front of the Cat all the way back and over the fuel tank and another one above the back box. Has someone removed some of them?
My car is stripped completely inside and my car is supercharged after a good thrash I can feel the heat through the floor but not enough to melt anything....
Posted 20th Feb 2015 at 22:41
Puggitt
All the heat shields are there the whole way through. It was the first time starting iron a month but I still wasn't expecting that it would happen. But it was hot hot, like touching an operating temp radiator.
Posted 20th Feb 2015 at 22:59
Must be too close or touching then really I would have said. Mine only gets warm.
Posted 21st Feb 2015 at 13:39
Mossy1985
Are you sure there are no restrictions in the exhaust? No blocked cat for example? A restriction would heat up the exhaust gases
Posted 21st Feb 2015 at 13:44
Puggitt
Revs fine doesn't sound different than before, and no major comparative power loss so doubt it's blocked. I thing I'll just drop the centre hanger see if that'll fix it, the centre box is huge!!
Posted 21st Feb 2015 at 18:44
Puggitt
On this subject of exhaust tunnel, has anyone removed the second skin that's spot welded over top? Can you remove it?
Posted 25th Feb 2015 at 09:24
pete-gti
Soothing deff getting hot , get under there and see whas going on :-) take exhaust off if you have to
Posted 25th Feb 2015 at 10:17
Puggitt
I think I just have to get rid of the frankin beast of an exhaust and get a new one made, but no point until I charge it and get it on the dyno. The centre box takes up all of the tunnel and used to hit the ground before it was stripped, but I may be able to get away with it being lower now.
Posted 25th Feb 2015 at 18:12
Hawkesfire
Mine melted the paint inside the car on its first real run on a track day and i thought the car was on fire inside but its super high boost supercharged with a 3 inch exhaust system.... it does get hot when racing so much that you don't touch the tunnel when you come back in but its great for keeping the racing gloves warm on cold rainy days
Marty
206 Rallycross GTI6 SC SHB 425 BHP clutch eater !!!
Posted 9th Mar 2015 at 12:33
