Author Subject: installing engine/gearbox and suspension
Mossy1985
Hi guys, I'm going to be installing an engine and gearbox, rear axle and suspension and subframe and steering rack etc pretty soon. I'm looking for any advice or tips that people could offer perhaps from past experiences?? Things like is it possible to lift the engine and gearbox in together? Or does the car need lowering over the top for that? Any tips at all would be appreciated
Posted 12th Feb 2015 at 18:28
jeffers Forum Admin
Engine and box can go in together from the top, as long as your using a decent crane. Rear beam is easy enough with an assistant... Probs best jacking it into position with two jacks, can't comment on the subframe, it's the only thing on my car I've never removed!
Team Running Engine again!
Team Negative Camber!
Posted 12th Feb 2015 at 18:34
Mossy1985
Cheers Jeffery, it's me and my mate doing it all so we should be able to manage
Posted 12th Feb 2015 at 18:36
I found it helped removing the bonnet when fitting an engine with the 'box already bolted to it, i had already removed most of the front end (bumper, radiator etc).
I've removed and replaced a rear beam on my own, would be much easier with a helper as jeffers said.
Subframes are easy enough, just watch out for the mounting bolts being corroded in place and shearing them off. I think it was Owain that had issues with the upper front two, it should be in his project thread if you want to see what i mean.
Posted 12th Feb 2015 at 18:38
cully
get a crane to lift the engine and box it is feckin heavy you will break your back or kill your friend by dropping it on him if you try it without
Posted 12th Feb 2015 at 19:15
Mossy1985
Cheers guys, I've got a crane from work which should be man enough. Any tips on bleeding cooling system as no doubt it will be a pig being french?
Posted 12th Feb 2015 at 19:54
They're one of the easiest ones I've ever done.
open all bleed points, fill up till coolant trickles from each one and close as that happens, fire up with the cap off and top up if needed.
Posted 12th Feb 2015 at 20:03
Mossy1985
Great stuff cheers Mei
Posted 12th Feb 2015 at 20:12
Disco_Stu
Here are the links to the FAQ guides:
Engine
Coolant
Load more useful links on the FAQ Page
Peugeot 306 Gti-6 Track car (soon to be supercharged)
Project page
Blog
Posted 12th Feb 2015 at 21:00
Easy to fit engine and box as one with an engine crane - just remove the entire front end, slam panel, bumper, rad etc and it swings straight in. Yes
Posted 12th Feb 2015 at 21:27
oldbrownshoe
The filling need to be done from higher level of the highest bleeding point.
French military victories?
Did you mean French military defeats?
Posted 13th Feb 2015 at 07:38
Mossy1985
How is that possible? Won't the highest point be the matrix?
oldbrownshoe
Use header tank or park the car in a uphill
Its crucial to use the o-ring seal as in the photo, otherwise the air will enter.
Posted 13th Feb 2015 at 07:44
Mossy1985
I will get the front end jacked up high enough then cheers
Posted 13th Feb 2015 at 07:42
oldbrownshoe
Don't backflip the car in attempts to get high enough,
it's better to source some plastic bottle and rubber o-ring as shown above, if it's not tight seal you can warp also a teflon band.
underestimating this procedure could easily leads to head repair.
Posted 13th Feb 2015 at 08:19
fatlapit
Wtf open sll bleed points fill header tank and close bleed points when coolant has a constant flow. Top up as necessary
Posted 13th Feb 2015 at 10:40
Mossy1985
Will follow this as it makes sense and sounds simple job done
Posted 13th Feb 2015 at 10:45
MisterGTR
I just taped an old 5 litre bottle on as a header tanker. Leaked a wee bit, but ran the engine for 20mins (until the fans kicked in) and kept it topped up and the excess came out the wee tube.
The FAQs on here are good.
I think i would have been facing downhill but i've check the level since and it's fine and temps are 80s at most. Saying that it had been pretty cold.
Posted 13th Feb 2015 at 13:25
oldbrownshoe
That's the whole point, if it leaked than air got inside and could be trapped,
the end result of this process is air free closed cooling system 100% coolant, no bubble, nothing, nada.
i used to neglect the seal of the gap between the bottle & the header tanker and ended with bubble.
Posted 13th Feb 2015 at 14:23
Puggitt
You'll never have a complete are free system due to the valves in the rad cap. Fill it up as much as you can with all the bleed points open, close them as they start oozing or leaking, run the car keep topping up as it get the remaining air out and just check the matrix bleed point (before it gets too hot) after that it'll be fine to drive around and in doing so will bleed out any remaining air. Re check in a week.
Or get a fulcrom vacuum coolant bleeding kit and suck out all the air and replace it with coolant, turn on, walk away for ten minutes, put suction lead in coolant open tap leave ten minutes, come back put rad cap on, job jobbed. Recheck in a week LOL
Posted 13th Feb 2015 at 20:43
MisterGTR
I was saying some of the coolant mix leaked out as it was going in.
Drunk pendant - I'd like to see how you removed all the air from your coolant (hopefully not 100% but mixed) at 1 atmosphere. But anyway...the point of the header tank while the engine/fans are running is to get rid of the bubbles?
Posted 14th Feb 2015 at 01:08
oldbrownshoe
MisterGTR wrote:
1)I was saying some of the coolant mix leaked out as it was going in.
2) Drunk pendant - I'd like to see how you removed all the air from your coolant (hopefully not 100% but mixed) at 1 atmosphere.
3) But anyway...the point of the header tank while the engine/fans are running is to get rid of the bubbles?
1) I misunderstood you.
2) as long as the coolant temp is right after bleeding there is no air trapped in there, that's the purpose this procedure serves.
3 the point is to remove air traps, air bubble rise to the highest point, and if this point is higher than the radiator
cap, you need to the column of liquid in the funnel to be in a higher level.
some useful links:
https://www.youtube.com/watch?v=zUpXgAJ1gjU
http://www.allpar.com/fix/radiator-purge.html
http://www.troubleshooters.com/tpromag/200204/200204.htm
Posted 14th Feb 2015 at 10:22
