Author Subject: Fuel tank removal
Ben_W
Formerly gpm
Talk to me boys.
About ready to pull out the beam and the tank.
I've got access to the filler pipe on the drivers side rear arch, ive managed to free off the rusted clips holding the elbow.
Can see the bolts for the tank strap, what else do I need to know?
Thanks
Posted 10th Feb 2015 at 20:35
don't forget to unplug the wiring and pipes before dropping it.
Posted 10th Feb 2015 at 20:36
Ben_W
Formerly gpm
Is there any tricks to undoing the fuel pipes?
Posted 10th Feb 2015 at 21:01
Push the retaining tabs in with a screwdriver or similar whilst sliding them off.
  • Posted 10th Feb 2015 at 21:55
    do they usually done off ok without snapping any captive nuts?
    andrew315rawson@live.co.uk
    Moonstone phase 7 gti6
    Posted 10th Feb 2015 at 21:56
    Ben_W
    Formerly gpm
    Ok, got the car up in the air on axle stands..
    Looking at taking the fuel tank out. In the pic, I've disconnected the fuel line from the filter, that was easy enough, just push the white tab. How do I undo the other two? Is that elbow a joint I can undo?
    Also need to remove the fuel filler pipe from the arch. Easy enough to disconnect at the tank end, but how do i undo this little bugger? Doesn't want come off, have a feeling it's something to do with the yellow bit....
    Posted 14th Feb 2015 at 15:01
    Ben_W
    Formerly gpm
    Right, got the filler neck out and disconnected, that's fine...
    How the Hell do you undo these connections with the green plastic?
    These are the only things stopping me having the fuel tank out, there's this one by the fuel filer and another on the connections on top of the pump. Two cups of tea and much head scratching later, I'm still none the wiser...
    Posted 14th Feb 2015 at 16:05
    You have to press the 2 green tabs surrounded by the black part with a screwdriver and pull
    Posted 14th Feb 2015 at 19:59
    Ben_W
    Formerly gpm
    Yeah, thanks bud.
    Got it figures, just the one under the car was proper stiff and clogged up.
    Tank out first thing in the morning
    Posted 14th Feb 2015 at 20:43
