Author Subject: Interior light not working with doors open - RESOLVED
Kenan
Hi Guys, would like a little help please.
I have a T reg 306 Rallye and the interior light doesn't operate when the doors are opened but will when manually switched on with the key in the ignition.
Any pointers where to start looking please.
Posted 15th Feb 2015 at 21:54
Bobeek
door switch..take them off, clean the screw and the surface and put it back.. must be a good connection between the surface of the switch and the car...
if its not help then you'll need new switches.. around 5 quid on ebay..
Posted 7th Feb 2015 at 21:19
I have same issue on my drivers side door switch p**ses me right off ! Stupid design with the earth being the the screw ? I need to de rust the mounting hole without fecking up
Posted 7th Feb 2015 at 21:52
Kenan
Been looking on the interweb.... should the lights come on when I unlock the car/turn off the ignition?
Posted 7th Feb 2015 at 21:53
barrym
Mine don't.but I have been wondering about this also. I really miss turning off the ignition and the lights staying on for a bit. likewise would make getting the key in the ignition that bit easier
Black Rallye occassional toy
Posted 7th Feb 2015 at 22:26
Puggitt
No, only work with accessory power or the door being open more than about 15 degrees depending on the setting. No fancy linger or unlock activation, too French for that
Posted 8th Feb 2015 at 07:13
Kenan
Thanks for the reply's guys, I'll get them cleaned or replaced as required.
Another quick question, the key fob range seems a little short. Can I change the battery without needed to re-code the fob?
Posted 8th Feb 2015 at 08:51
willow
Hi Kenan,
Good to see you're on the case with sorting those niggles! The fob batteries is pretty new, I only changed them a month or two ago so it won't be that. It is quite a bit better than it was before! It is mostly a case of getting the aim right, but I think the infra red remotes always have a pretty short range.
(And yes you can change the battery without recoding or anything like that, it is just a straightforward swap.)
W.
Posted 8th Feb 2015 at 13:27
Bobeek
just be careful when you're taking off the switch...the wire can slip off from the swich very easily and if its does and fall back in the hole..then good luck to pull it out.. Wink
Posted 8th Feb 2015 at 20:34
Kenan
You sound like the wife !! Have adjusted my aim and now works much better Thumbs up Plan to work my way through the niggles and get her sorted. I might of temporarily encouraged the radiator to stay in place with a cable tie or two . . .
I have proved the switch is at fault (I think) by earthling one terminal on the switch off the car resulting in a working light and now have on one order to prove the point.
Posted 9th Feb 2015 at 19:54
Kenan
It was only the door switches at fault, assumed it would be more complicated but not complaining.
The connector on the end of the loom was the same size as the hole the switch was sat in so no way I was getting the switch out with the wire attached. This lead me with a solution to retrieve the wire, just stick a flat head screwdriver into the terminal, twist it tight and remove.
Posted 15th Feb 2015 at 21:58
Puggitt
Yeah those door ajar switches are shockingly terrible, break down all the time, but I guess the rubber boots wear out and let water and what have you into the switch. But I've replace numerous quantities of them.
Posted 15th Feb 2015 at 22:21
Same switch as the handbrake light for info.
  • Posted 15th Feb 2015 at 22:23
