Author Subject: 315mm AP Racing brake rotors
jorg
I have a used pair of AP Racing brake rotors for sale.
the product numbers for these are CP5000-212/213G8
315mm diameter
28mm thickness
PCD Diameter: 177.8mm
12 bolt mounting holes
if you require anymore info or pictures please ask Smile
£100 delivered
306 2.1 S16 Tarmac Rally Car
Posted 31st Jan 2015 at 18:33
pugheaven
Please keep hold of these until I get the dimma back so I can check they are the same as mine
Posted 31st Jan 2015 at 18:49
jorg
just had a quick look through your project thread mate and they do look very similar Yes
i have the same mounting bracket for my cp5200 calipers but no bells to use with rotors, its a shame as i can just squeeze them under my 15" pro race 2s Sad
Posted 31st Jan 2015 at 19:10
jorg
Bump... will also have some 300mm AP Racing rotors up for sale later
Posted 27th Mar 2015 at 12:37
any calipers thatll work with them or the 300's? same pcd?
is it the diameter that causes issues with the 315 and the pro race 1.2's?
Posted 27th Mar 2015 at 13:12
jorg
I have the cp5200 calipers and brackets to go with the 315mm rotors but no bells Sad would of used them if I did. just checked and that setup requires a 20mm spacer to clear 15" 1.2's.
might have a pair of ginetta/hi-spec 4 pots which would go well with the 300mm rotors.
Posted 27th Mar 2015 at 13:39
