Author Subject: Differing torsion beam thickness?
Ben_W
Formerly gpm
Been reading a little about beams etc as I'm looking at having the one off my Rallye to clean it up.....
What effect does changing the thickness of the torsion beam have? I'm assuming it alters the suspension rate, much like differing spring rates do on spring and strut set ups?
Why are the 21mm Xsara ones in demand?
Thanks
Posted 18th Jan 2015 at 17:09
you mean torsion bar not beam, beam is the name for the whole assembly
21mm are stiffer than 20 by about 20%
Posted 18th Jan 2015 at 17:29
craig903
every 1mm increase stiffens the rear beam at a rate off around 25%. I remember reading this somewhere. so maybe someone else can clarify it?
208 GTI Owner
Posted 18th Jan 2015 at 17:30
clen666
20mm | 100% | 110lb (i.e. standard)
21mm | 122% | 150-180lb (i.e. Eibach 7011)
23.5mm | 191% | 300-350lb
25mm | 244% | 450lb
That info was taken from a thread posted a while back
Team 'unintentional rat look'
Posted 18th Jan 2015 at 17:58
Ben_W
Formerly gpm
OK, that confirms what I thought......thanks.
So is the 21mm swap worth doing??
Posted 18th Jan 2015 at 18:05
jord294
Depends what you want from the car??
Posted 18th Jan 2015 at 22:16
I had 24's on till a while ago and were spot on in a smooth track environment but to bouncy even with GAZ's cranked up to control them when on the road.
As said depends what you want from the car and how much or little weight you have at the back as well as your driving style.
Posted 19th Jan 2015 at 13:58
Ben_W
Formerly gpm
I'm not quite sure really. Something responsive but not crashy, something that's going to stand up to some fast road driving and enhance the handling......
Posted 19th Jan 2015 at 20:00
I'd just go for 21's personally but I've found that having decent rear shocks with adjustable bump and rebound makes more difference.
I'm currently running 21mm bars with GAZ Gold adjustable dampers. I massively prefer them to B6 rear dampers which most people tend to go for as their slightly stronger than standard but not too solid. Depends what your budget is.
A lot of people find they can't get the bars out anyway LOL
Posted 20th Jan 2015 at 10:20
Ben_W
Formerly gpm
Thanks for that.
I'm half tempted to buy another beam in bits and clean it up and rebuild it. Doesn't matter it the torsion bars won't come.out of the old one then...!!
Thanks for the shocks advice, that's useful
Posted 20th Jan 2015 at 20:52
jord294
What front suspension set up will you be using?
Posted 20th Jan 2015 at 22:13
