Rallye Race Car
| Author | Subject: How to remove dash board support / steering column cover |
demondriverdan
I've taken the dash out of the car but not sure how to remove the metal support that is behind it and on top of the steering column? There is a piece of sound deadening behind it I want to remove. ________________________________________ Rallye Race Car |
pugheaven
Seasoned Pro Location: Fareham Registered: 17 Dec 2006 Posts: 4,602 Status: Offline |
Undo the 3 bolts in the engine bay, 2 under the scuttle panel and 1 half way down where the brake lines run, once you have undone them you have 4 17mm nuts holding the metal steating column bracket, iirc the two top ones and the lower inboard ones are left handed threads and the one by the accelerator pedal is right hand thread and so is the bolt going through the 17mm nut |
demondriverdan
Cheers Ollie, hadn't thought about left handed threads. ________________________________________ Rallye Race Car |
pugheaven
You can just tear the soundproofing out though, it just covers the brake master cylinder nuts |
I managed to pull 99% of that pit without taking it off. Bit fiddly tho.________________________________________ Black power baby! SUUUUUPERCHARGED Seat Leon FR TDI 190BHP 300lbft daily gti-6 killer :p 12x 306's owned so far Cambelts, clutches, service work carried out on All makes and models, Peugeot Citroen / mitsubishi specialist. Pug planet / Citroen Lexia diagnostics / code reads available. |
