Author Subject: cat to manifold joint
pete-gti
Just making sure this looks ok , part the gasket is meant to be showing still?
Just hard to see if its made a good joint or not
Posted 31st Dec 2014 at 11:50
ian7675
Techno Viking
Yeah, the gasket is beveled and will show slightly.
Less than 24 hours to go!
Posted 31st Dec 2014 at 12:16
Looks good to me
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 31st Dec 2014 at 14:33
yup just wind the nuts till they bottom out.
nylocs will be useless there though, the o.e locking nuts are more suited to that application.
Posted 31st Dec 2014 at 16:43
pete-gti
Just used what came with the kit , alright the same sort that you use on the drive shaft bearing housing?
Posted 31st Dec 2014 at 17:21
thats the ones.
Posted 31st Dec 2014 at 18:00
ad
Not that it really matters but i thought there should be 4 washers and one sits on top of the spring against the "flange"
I also make my own bolts with thread as i always find that the bolts supplied with those kit don't do up enough for my liking, they always seem to let a little fart noise out when putting your foot down.....
Posted 31st Dec 2014 at 18:43
not if you buy the o.e kits Smile
Posted 31st Dec 2014 at 19:01
ad
Ive tried all sorts over the years and still find my "home made kit" works just as good.
An 8mm threaded bar with a 10mm nut on top wound down a few mm, cut down the middle of the threaded bar with a hacksaw down to 10mm nut. Then burr the ends over the nut with a hammer and your done- cant remember if i put a washer on the bottom of the nut or not so it doesn't pull through. its always worked for me.
Or you could just buy a kit.....
Posted 31st Dec 2014 at 19:29
how do you get an m6 nut on an m8 bolt?
Posted 31st Dec 2014 at 19:45
pete-gti
seems ok will no for sure once its running
ad
I get a 10mm nut with an 8mm thread and put it on.....simple. My old man has a lot of stuff in his shed.
Posted 1st Jan 2015 at 10:35
ad
A bit like this if the photo uploads...
ad has attached the following image:
Posted 1st Jan 2015 at 12:10
I used the smaller ones, was a complete and utter bas**rd to fit them tho
Posted 1st Jan 2015 at 12:42
Maybe he ment a 10mm head as in a 10mm socket.
Where's the bloody common sense gone to with some people, unless you allready knew that and was just been awkward as usual
Posted 1st Jan 2015 at 12:45
ad
That is what I meant, I can't get technical. 10mm head, 8mm thread, bobs your uncle.....
Posted 1st Jan 2015 at 12:53
cully
cough! 10mm head 6mm thread Wink
or 13mm head with 8mm thread
Posted 1st Jan 2015 at 13:47
I knew exactly what you ment anyway lol
Posted 1st Jan 2015 at 13:54
pete-gti
Don't no why they make them so short extra 10mm would help lol
Posted 1st Jan 2015 at 15:51
