How far is it ment to go in? Is it met to be flush with this side?
Author | Subject: drive shaft bearing |
![]() Seasoned Pro ![]() Location: Kent Registered: 15 Feb 2009 Posts: 1,297 Status: Offline |
![]() aka JKshooter ![]() Location: Taunton, Somerset Registered: 15 Jun 2006 Posts: 10,308 Status: Offline |
When you tighten the nuts up it will pull the bearing home.________________________________________ ![]() |
![]() Capt Pedantic ![]() Location: Bigend, Wales. Registered: 27 Mar 2007 Posts: 25,847 Status: Offline |
not advisable really, only m7 bolts and they bend easily.best bet is to clean both parts thoroughly and you'll feel/hear it clunk home, the size of the collat holding the bearing in place varies so they won't all look the same. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
![]() Seasoned Pro ![]() Location: STOCKSFIELD Registered: 02 Nov 2010 Posts: 3,040 Status: Offline |
stick some copper slip in that will help it________________________________________ |
it might all be good but im not sure , the bearing is flush with the hole on the side you push it threw, will get some pictures see what you guys think |
![]() Seasoned Pro ![]() Location: Crowborough Registered: 22 Mar 2008 Posts: 3,445 Status: Offline |
When ever I remove a shaft I always clean up the bearing with either a scotchbrite pad on a die grinder or some emery cloth. Then cover it in copper slip. Goes in easy as anything and comes out next time. The bolts will pull it in all the way if you do them up evenly. But as said if it's to tight going in then I wouldn't force them. ________________________________________ Black power baby! SUUUUUPERCHARGED![]() Seat Leon FR TDI 190BHP 300lbft daily gti-6 killer :p 12x 306's owned so far Cambelts, clutches, service work carried out on All makes and models, Peugeot Citroen / mitsubishi specialist. Pug planet / Citroen Lexia diagnostics / code reads available. |
![]() Seasoned Pro ![]() Location: Winchester Registered: 21 Nov 2003 Posts: 13,753 Status: Offline |
Never had any problems just using the bolts to pull the shaft into place |
will get a picture tomorow , i greased it up a tad bearing has gone into the housing just waiting on getting some new nuts for it , just not sure if its far anough in if anyone has a picture be apprecaited |
bearing looks seated, but why two nuts? standard ones are locking type.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Found by using a over size nut it fitted into the hole nicely to act like a washer , then put the normal locking nut on found it a lot easyer to tighten it up as it gave me more room for the ratchet and be Easyer to remove if ever need to , when I first removed these I had to grind bit of my 11mm long reach socket down to fit into the recess hole as it wouldn't go in So I've just done this to makes it easyer for me lol :-) |
