Dave
| Author | Subject: Fitting baker b m adjustable top mounts |
Mossy1985
Senior User Location: Darlington Registered: 04 Nov 2014 Posts: 545 Status: Offline |
Looking to see if anyone has fitted these or has maybe even made a guide/how to?Dave |
Niall
Seasoned Pro Location: Epsom Registered: 06 Jun 2012 Posts: 1,941 Status: Offline |
A Mate of mine has. You need to cut a bit out of the turret hole so you can go to full camber (without opening it up, you can stay at standard and thats about it)Other than that, its pretty self explanatory. You'll need some conical top hats. |
Mossy1985
Ok mate what is conical top hat?Dave |
fatlapit
i have look at my project thread________________________________________ |
fatlapit
u will never need 3 degrees camber on the road________________________________________ |
demondriverdan
I got my conical top hats from Gaz, pretty cheap (£15 IIRC)________________________________________ Rallye Race Car |
fatlapit
baker bm can machine anything u need________________________________________ |
Mossy1985
I had a look at your thread (top marks for effort btw) but I'm still a little confused as what I need?? I thought they came with everything needed to fit to the vehicle? |
Are you running stock suspension? Or coilovers ? |
Mossy1985
I've just bought a full b8 set up mate |
not sure if you can run baker top mounts on std style suspension ? I thought you had to run coilovers |
Mossy1985
Well if that is the case it certainly isn't advertised that way on their Web site, but knowing my luck it will most likely be true |
Mossy1985
Well after reading some older posts you bbb are quite correct and I am unable to use these ffs. Hopefully baker will accept them back and give me a refund |
Ask them if you can use normal suspension first ? Stuart may have adapters to run b8s ? Or sell the b8s and get some Bilstien coilovers ? Plenty will have the b8s off you ? |
Niall
You won't be able to unless you keep them at standard camber which then you may as well use standard top mounts...They will last longerThe springs will end up hitting the inner turret |
3 options then Send them back Get coilovers Sell them on |
fatlapit
send back a top mount and a b8 and stuart will do the rest. #getitdone________________________________________ |
Do you need negative camber ? Not much benefit on the road ? Only useful on track if you have adjustable this and that and know how to use it ? |
Mossy1985
I really want the option of it as I'm serious about getting some track time under my belt |
Capt Pedantic Location: Bigend, Wales. Registered: 27 Mar 2007 Posts: 25,868 Status: Offline |
you won't have the option with standard springs.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Mossy1985
Well live just bought my b8 set up so I'm not selling to try and find some coilovers, so it's either going to be send them back or see if they can do anything for me |
demondriverdan
The other option for camber is to have the hubs machined but obviously then it's not adjustable!________________________________________ Rallye Race Car |
it can be done with offset bored sleeves, whether anyone offers that rather than just an altered angle and a straight bore sleeve I dont know, but it wouldnt be difficult to do.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
daver6
Seasoned Pro Location: Durham Registered: 08 Aug 2010 Posts: 2,379 Status: Offline |
Mossy1985 wrote: Well live just bought my b8 set up so I'm not selling to try and find some coilovers, so it's either going to be send them back or see if they can do anything for me Sell me the B8s ________________________________________ Red Rallye - Rolling "restoration"Wishbone Polybushes available |
Mossy1985
Lol no way daver I'm only just picking them up 2mos |
