| Author | Subject: radiator thermostat coolant |
curlz1987
Newbie Location: ipswich Registered: 06 Jul 2014 Posts: 9 Status: Offline |
Hi I have a 306 gti 6 iv just replaced the thermostat because I thought it was stuck open I have had problems with cutting out wen hot like 90degs. And stutters sometimes wen gunning it. Also my heating seems to be luke warm not hot. Iv bleed the system all three bleed points. I dont seem to be getting much pressure in the top rad hose. I cant c it being the head gasket as I dont loose any water plus there is no water in the oil.cars runs around 78 degs at 30 to 80 mph. Thermostat works fine opens at 83 deg. Any help welcome |
Probably needs a new matrix or at least it flushing out.stuttering could be a number of sensors on the engine. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
curlz1987
Its running through ok and both pipes are hot coming out where the thermostat is. The bleed screw top left bulk head flows out out no probs. Just dont know why theres not a lot of pressure in the top rad hose. Normally hard to squeeze once up to temp but its got hardly any pressure at all |
only gets hard when the hg goes tbh.try a new cap anyway ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
curlz1987
What rad cap? |
Thanks for your message.Your feedback is important to us. ________________________________________ ![]() |
curlz1987
Heating is bothering me more as its coming into winter. Set on cold its cold wen set on hot it just about comes out luke warm. Theres no air locks coolants coming through the matrix fine dont understand why it's not hot |
curlz1987
Any 1 on here |
have you removed the matrix pipes and back flushed the matrix?________________________________________ andrew315rawson@live.co.ukMoonstone phase 7 gti6 My Project thread: http://www.306gti6.com/forum/showthread.php?id=119992&page=1 |
curlz1987
Just the bleed srew and return pipe from heating matrix both flowing fine. Car runs around 75 to 78 deg wen doing over 30 is that normal |
Could it be the air direction part in the heater box area behind the dash? Not sending air through the matrix to heat it up.________________________________________ Goldie the track car. |
curlz1987 wrote: Just the bleed srew and return pipe from heating matrix both flowing fine. Car runs around 75 to 78 deg wen doing over 30 is that normal Just the bleed screw only won't show you how it's flowing. Other than that the flap as said above, is there anyway to see it moving without removing dash? ________________________________________ andrew315rawson@live.co.ukMoonstone phase 7 gti6 My Project thread: http://www.306gti6.com/forum/showthread.php?id=119992&page=1 |
curlz1987
It might be. not sure how to get to it 2 check it out though. will av 2 google it 2 c where it is. It must open a bit cause it warms up just not as hot as ud expect it 2 be. Like it's set on 21 deg and not full heat.any 1 know if u can get 2 it behind cdplayer. Cheers for the help ppl |
curlz1987
curlz1987 wrote: Any 1 on here Very few these days. ________________________________________ ![]() |
curlz1987
Yeah I think it maybe the flap was playing around with it on way to work every time I turned it to cold then hot again it would get hot then next time it would go cold or luke warm so might be possibly sticking a bit |
ad
Regular Location: High Wycombe Registered: 15 Aug 2004 Posts: 284 Status: Offline |
Might be a sensor in the dash itself, also the little fan/ temp sensor in the roof by the light might need a clean as it can clog up with dust ect and get a false reading....It could be a number of things though, we all know what these cars are like. How much antifreeze have you put in? Is it the right stuff ect ect Good luck. |
Rich E
Moved from Feedback________________________________________ Rich |
dangti6 wrote: Thanks for your message. Your feedback is important to us. never noticed till last post, I wondered what you ment, I just thought you felt like been a bit random ________________________________________ andrew315rawson@live.co.ukMoonstone phase 7 gti6 My Project thread: http://www.306gti6.com/forum/showthread.php?id=119992&page=1 |
