Author Subject: Quick starting problem
gilesy
Hey you crazy lot.
Currently waiting for the AA outside Victoria in London. Drove here to pick my friend up.
Got back to car and thing won't start. Thinking it's an immobiliser problem. Any quick fixes (other than waiting for the AA man)?
Retro phase 1 with keypad.
Posted 14th Dec 2014 at 21:39
check the inertia switch and the battery terminals.
does it turn over?
Posted 14th Dec 2014 at 21:43
gilesy
Checked the switch and seems to be down, can't press it anyways.
Terminals are tight and I've only done 20 miles since I filled it up.
Turns over and fuel pump primes
Posted 14th Dec 2014 at 21:46
Pump da gas.
  • Posted 14th Dec 2014 at 21:47
    gilesy
    Pumping da gas has no effect :-)
    Posted 14th Dec 2014 at 22:04
    tried disconnecting the battery and then put it back on ? Sounds like no spark
    Posted 14th Dec 2014 at 22:15
    gilesy
    Yep I've tried that already
    Posted 14th Dec 2014 at 22:16
    Keypad goes green once code is put in ?
    Posted 14th Dec 2014 at 22:21
    gilesy
    Yep. It's the crank sensor :-)
    Posted 14th Dec 2014 at 23:55
