Author Subject: Intermittent "splutter"
DanRM
Recently I have been having problems with my 6, its completely standard with a full head rebuild done by myself roughly 3k ago. The car has been running good since, except in the last couple of weeks occasionally when driving the engine will splutter and not allow me to accelerate. This happens for a few minutes every now and then until it seems to clear and carries on fine. The closest thing I can describe it to is its choking, seems very similar to when I have driven my 106 through a puddle thats a little too deep and it coughs for a few minutes after until it clears out.
My main problem is that its too intermittent, so I'm finding it hard to check it over when its at fault, but its starting to get more regular and becoming dangerous for me as last night i was on a slip road, put my foot down and it decided to happen and wouldnt accelerate.
The other thing I have noticed more recently is that it doesn't do it from cold, it's either once I've driven it 20 from work and left it for an hour or so when i'm at my parents before going home, or half way home from work down the dual carriage way.
I have replaced theCTS Map and stepper with new, and I swapped my genuine CAT and Lambda from my other 6 as they were in better condition and my other 6 drove faultless.
Any ideas what it could be? only other problems I can recall at the moment is the speedo is cutting out intermittently (but neither happen at the same time) and sometimes the air bag light will stay on unless I switch the ignition off and back on
Posted 13th Dec 2014 at 18:58
jeffers Forum Admin
I'd try looking at the speed sensor first.....
Team Running Engine again!
Team Negative Camber!
Posted 13th Dec 2014 at 19:47
I'd replace the speedo drive first as it may be causing the problem but I suspect it's prob something like throttle position switch or maybe a bad earth / bad battery terminal ?
Are you running an induction kit ? They have been known to rub up against the loom at the front of the car and cause problems
Posted 13th Dec 2014 at 20:10
DanRM
No, just the standard induction. I have swapped the coil packs from my other car and haven't had the problem in the drive from my parents house to home...yet. Speedo is on the back of the diff housing is it not? I have been in and around that area whilst sorting out my exhaust and linkages so my have caused a bad connection. Just hoping to sort the major bugs before I put the other 6 on ebay and have to pay for new parts rather than swap them
Posted 15th Dec 2014 at 22:38
DanRM
Having to bring this thread back up after fixing the speedo drive it still had the problem, then I found that oil was leaking down through to the air filter housing which I posted a thread about here http://www.306gti6.com/forum/showthread.php?id=162194. Up until a couple if days ago I thought I had sorted it with no splutter for a while but the last couple if days its been spluttering and struggling near enough every drive. I'm planning on booking it for a few tests next week as I'm stuck for answers as the car has used from max to min marks worth of oil since the 23rd Dec yet its not smoking and there are no visable leaks. Just before I do though has anyone got ideas what I'm looking at here?
Posted 18th Jan 2015 at 12:11
pete-gti
Could be any of these
lambda sensor
Tps sensor
Map sensor
Green coolant sensor (ecu)
Or a bad earth , my earth cable was shaged from battery looked fine , but had a brake in it somewhere
Posted 18th Jan 2015 at 15:25
DanRM
Cheers for the reply, I've changed the icv and map sensor, the lambda and throttle position sensor will be replaced soon, but I've decided that the missing is down to the air filter being clogged with oil, as the same head happened again as what's wrong in my other thread linked above. It seems to be coming down the breather pipe into the throttle body again Sad
Posted 19th Jan 2015 at 17:26
pete-gti
Fit oil catch tank?
Posted 25th Jan 2015 at 20:31
DanRM
Update on this Friday I borrowed a compression tester as no where round me seems to have a leakdown tester, starting from belt side I got 150, 166, 205 and 250. With the first 2 being well in the green mark on the tester I used and the other 2 in the "too high red" gauge. It is also cylinders 3 and 4 I am getting a lot of build up on the plugs where the other 2 are clean. This to me sounds like there is oil in those cylinders?
Yesterday I put some forte engine flush through there, renewed with genuine pug filter and total quartz 7000. Whilst doing this I cleaned off all the filter housing and fitted a new element. I also blocked off the part the breather goes into on the throttle body (what is that exactly?) and I put the pipe going into a bottle by the battery box. Hoping to monitor my oil loss and save buying new filters. Took it for about 15 mile drive and a very little among was in the bottle, what I would expect to see normally. I went out this morning and the filter housing has got nice clean oil around it again, btw I slackened the jubilee clip so most would run out rather than puddling in the filter. So I'm baffled now on how the oil is getting into there.
Posted 8th Feb 2015 at 16:06
