Author Subject: Air con delete bolts or sizes of bolts
Mossy1985
Hi guys, just bought an air con delete kit from my local factors, got the two ina tensioner/idlers and gates belt for 73 quid which I didn't think was bad? But I got them to call pug for the bolts and they only sell themin batches of 10! Well I don't need that many so would anyone have some that they bought from pug and that are left overs? Or can someone tell me thread size/pitch/length and I can go to my local fasteners?
Dave
Posted 27th Nov 2014 at 07:39
Nose
Thats a very good price Dave!
Bianca 306 Rallye.
Mondeo Titanium X.
Posted 27th Nov 2014 at 18:34
jeffers Forum Admin
Iirc they're standard M8 20mm long, except for the tensioner bolt which is still M8 but about 100mm long, il check service box and come back to you! Thumbs up
Team Running Engine again!
Team Negative Camber!
Posted 27th Nov 2014 at 18:38
RetroPug
Try Warners Peugeot in Tewkesbury they might post out one bolt.
Posted 27th Nov 2014 at 18:57
Mossy1985
yea I was happy enough with it with the parts being INA and Gates
Posted 27th Nov 2014 at 19:16
Mossy1985
I did attempt to find them on servicebox but failed lol tbh I think i was looking at the wrong engine whoops
Posted 27th Nov 2014 at 19:18
Use the same bolts for aircon set up ? You just need a long bolt for the tensioner
Posted 27th Nov 2014 at 19:57
jeffers Forum Admin
You have to look at the phase 1 parts or non restyled parts list.
Roller 5751 33
Tension roller 5751 32
Self locking self tap screw m8 x 4 25 mm
Tensioner screw 5703 67 x1
Hope this helps!
Thumbs up
Posted 27th Nov 2014 at 20:37
none of the parts above are listed for a phase1, only a phase2/3, an 806 and a 406, because the J4R engine came in those cars without AC.
phase1 306 never got the J4r as the XSI was only 8v at the time, nor or a J4RS without AC, and the S16 used a different bracket.
Posted 27th Nov 2014 at 20:51
Mossy1985
So I get that I need 4 bolts m8 which are 25mm long, but the other bolt is that an m8 that is 67mm long?
Posted 27th Nov 2014 at 21:10
no, that's the part number, there's no length listed for it but its around 75mm I think.
Posted 27th Nov 2014 at 21:14
You already have the bolts if your running an aircon setup ? - why you no listen ?
Posted 27th Nov 2014 at 21:29
he won't hsve the lomg bolt.
Posted 27th Nov 2014 at 21:44
Mossy1985
I'm sorry Unsure so I just need the long bolt for the tensioner and if welshpug thinks 75mm ish I will get one of those and I'm sure it will do, thanks guys
Posted 27th Nov 2014 at 21:50
jeffers Forum Admin
Sorry! Either way thats the part numbers that are required! Roll eyes
Posted 28th Nov 2014 at 08:13
he won't hsve the lomg bolt.[/quote
I know that's why I said he would need it ! FFs
Posted 28th Nov 2014 at 13:03
