Author Subject: Cheapest way to delete AC with new bits?
studarude
Has anyone got any ECP part numbers or ebay links for the tensioner, idler and belt to delete the AC pump?
Been digging around and found an idler for about £18 but cant find a cheap tensioner, belt too..
Anyone? Dont really wanna go down the 'rare rallye aircon delete kit' when any non-AC XU10 (to a point) will do.
Posted 10th Nov 2014 at 23:40
jeffers Forum Admin
If you have the pug part number for the tensioner, ring ECP and they will match it up with the equivalent part, that's how I did it anyway.Thumbs up
Team Running Engine again!
Team Negative Camber!
Posted 11th Nov 2014 at 05:24
MisterGTR
Could I ask a favour and you keep the ac pipe that goes from the left of the engine under the fuel lines round the back of the engine into the bulk head. The one with the spring clip.
Can send you a pic of required.
The reason is I can't get my clip to hold so want to see how it works. Will post back and pay for the loan. Ta
Posted 11th Nov 2014 at 12:38
pete-gti
Is it the seflf loaded spring tensioner you need?
Posted 11th Nov 2014 at 12:58
The parts are pretty expensive separately dude Yes
Posted 11th Nov 2014 at 13:42
studarude
Hi guys,
Its the idler, and tensioner that is used on non-AC XU10's, like the rallye, 406 etc.
MisterGTR: Im afraid i've never had the pipework, the engine is in a 205 Razz im converting it to run a VTS power rack so need the bits to tension the belt and drive the pump.
Best ive got so far is about £65 in bits from all over, ebay for all the bits bizarrely...
Posted 11th Nov 2014 at 14:54
Not going to beat that by much
Posted 11th Nov 2014 at 15:53
MisterGTR
Ah no worries. Thanks for the reply. And best of.
Posted 11th Nov 2014 at 19:49
