Author Subject: wrong main bearing. crank is stuck. what bearing?
wille_89_
hi in summer my gti6 Engine was destroyd i dont know why, failer in bengine, big end bearing and main bearing was destroyd. i changed them in summer, i putted in my xu10j2 crankshaft from 1996 into my gti6 Engine.
i had Heard that the original was the way to go to put in Engine if the crankshaft bearing never had been changed which never had been changed so i ordered them,
now the shaft is stuck and Asbjörn a good friend to me said that i had to be messured becaouse its very many different main bearing in Engine. so i have bought a micro meter now, do you guys know what exaktly main bearing in the j2 crankshaft from 1996 should have for exaktly bearing,
or do i have to messure them, the car is 400 km from here so its hard to go down and messure, when i have to order the new bearing. somebody know what main bearings? the big end bearing should be the right ones Asbjörn said becaiuse its only 2 to choose, and i have original.
heyhey Smile love 306 its the best and most fun car i ever driven.
Posted 8th Nov 2014 at 13:22
jeffers Forum Admin
I'm not completely sure but I don't think that crankshaft is compatible with the RS block. Sure welsh pug will be along shortly to correct me if I'm wrong! Thumbs up
Team Running Engine again!
Team Negative Camber!
Posted 8th Nov 2014 at 13:40
wille_89_
all xu10 crankshaft should, fit at least what i have read everywhere, and also what Asbjörn said
please help?
Posted 8th Nov 2014 at 23:24
allanallen
Standard sizes are
Mains 60mm
Big ends 50mm
Facebook
Posted 9th Nov 2014 at 09:04
rich_w
You need to measure the bearings – there’s no way around it.
The XU10J2 and XU10J4RS have the same journal and tunnel size – so the bearings and crankshafts can be interchanged.
The standard bearing sizes are 60.00 on the mains and 50.00 on the big-ends.
The first undersize is 59.70 on the mains and 49.70 on the big-ends.
You may have been supplied the incorrect bearings – the standard main bearings should measure 1.845 thick.
Cheers,
Contact Details:
07732 822546
Posted 10th Nov 2014 at 11:16
