Author Subject: Weird noise from engine
sparkie1984
Hi all,
noticed the other day the cars started making a weird noise, it increases with the revs of the engine. I have a couple of videos of it which ill post. Typical just as i wanted to sell it.
and this is one of it driving along at about 4K rpm towards the end of the video you can hear the noise disappear as the clutch is dipped
any chance it could be something simple like a loose spark plug or is it going to be something more?
built on: 15 January 1999 - that's a Friday afternoon car..eek!!! ;o).........sadly missed
Posted 2nd Nov 2014 at 18:10
pete-gti
Possible loose spark plug Smile
Posted 2nd Nov 2014 at 18:46
sparkie1984
I'm hoping so! Have ordered a spark plug socket for my socket set so will check it out
Posted 2nd Nov 2014 at 21:54
If it stops when you press th clutch then I'd say it was a thrust bearing issue
Posted 2nd Nov 2014 at 22:12
sparkie1984
Once the revs drop it stops, or at least quietens down massively, seems very influenced by the revs.
I'm not sure what a thrust bearing is, how can I check that?
Posted 2nd Nov 2014 at 22:14
Sounds like a bottom end knock in the first video. In the second one could be bottom end or knackered gearbox / diff problem as it goes when you press the clutch and cut the gearbox speed.
However without being there it could still be bottom end knock and it's just quieter on idle when warm so when you dipped the clutch it went quiet but when going Along at 4k it's loud.
Posted 2nd Nov 2014 at 22:36
Thrust bearing is attached to the clutch pres plate. How old is the clutch ? Mileage on the clutch ?
Posted 2nd Nov 2014 at 22:52
sparkie1984
I'm not sure about the clutch mileage to be honest, the cars on 145k though.
Bottom end issues doesn't sound good or cheap to fix so Sounds like it might be time for the car to meet its maker.
Thanks for the advice guys
Posted 3rd Nov 2014 at 06:17
jamiek_uk2000
It's not too bad doing the bottom end, but easier to just change the engine.
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 3rd Nov 2014 at 09:01
sparkie1984
To be honest if it's that I think, I'll have to just sell it as it is.
Might be of use to someone for a track car or for bits
Posted 3rd Nov 2014 at 09:19
just check the plugs first, but I wouldn't go running it much and definitely would not drive it as yiu gave s high chance of rendering the whole engine scrap if it is bottom end related.
Posted 3rd Nov 2014 at 12:43
sparkie1984
Thanks mate, I'll check the plugs and if it's not that then I'll have to sell it as is.
Posted 3rd Nov 2014 at 12:49
sparkie1984
Well unfortunately my socket set doesn't have a long enough bar to take each plug out.
However the spark plugs are not loose enough to undo by hand (without the ratchet bar on) so I doubt it's a loose spark plug.
Posted 6th Nov 2014 at 19:30
