Author Subject: Top hose internal diameter
jamiek_uk2000
What's the size, I'm ordering up a revotec fan controller for my slimline fans. The standard system is wrecking me
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 28th Oct 2014 at 13:44
chiefton
why do you need to know the hose diameter???
its the size of the fan switch on the rad where the controller screws in im sure. I cant remember tho so not much help LOL although I do have one fitted due to the standard system being rubbish on mine also lol
cherry rallye daily (the money pit)
Posted 28th Oct 2014 at 18:33
nowt wrong with the standard fan system and fan switch, M22 is the thread.
Posted 28th Oct 2014 at 18:35
jamiek_uk2000
I have an issue with the fans not always working when I start the car. I've taken everything apart, checked, cleaned, refitted, changed things and now it still has intermittent issues. Damn French wiring.
Revotec controller is 40 quid and it is a fit and forget
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 28th Oct 2014 at 19:22
jamiek_uk2000
Which one is the coolant temp switch? If I change it for the revotec item, will it affect the system. (Does the switch send a signal to anything else but the fans?)
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 28th Oct 2014 at 19:24
I think the brown one is the fan temp controller.
If you unplug the connector the fans should spin up on a working system.
Posted 28th Oct 2014 at 20:32
bin the ac fan system for the non ac one, say off a turbo diesel or similar, they use the two speed thermoswitch in the rad, hook up the wiring to your small fans.
I'm using the rallye type arrangement on the ZX, switch cost £12, god knows how much the loom was, came off a diesel ZX in a breakers, pence!
(you'll need to rob it from a 306 as the ZX one just plugs straight into the shunt box)
revotec controller wont work with the ac fan system.
Posted 28th Oct 2014 at 20:50
jamiek_uk2000
I've already binned the A/C and linked out the two fans to run together, infact it's only since I've done that I've had the problem.
I'm changing to slimline fans to give me more room in the front for the oil cooler and possible charge cooler, so it will be a whole new cooling system, since I would be bodging in the new fans to the wiring anyway
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 28th Oct 2014 at 22:48
I'd get a non a-c loom and start afresh then really, all you'd need to do is connect the two fans up and plug it in.
Posted 28th Oct 2014 at 22:56
jamiek_uk2000
Scrappy for me on Saturday morning then!
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 29th Oct 2014 at 11:33
