Author Subject: Rear damper change?
luke89
Hi folks,
My car sits about 10-15mm lower on the drivers side rear than the nearside rear and I have been informed it is most likely the rear shocks?
Now I would like to rectify this however If its a case of removing the rear beam to do so I won't have the time. I'm handy enough with a set of spanners but my tools and lifting gear are all in Blackpool at my parents house and I'm living in Manchester so its a 2 hour job just getting the gear together which isn't great when I have one day a week off!
If the shocks can be removed without taking the whole rear beam off I think I will tackle the job myself.
Cheers!
Posted 17th Oct 2014 at 18:43
allanallen
Rear shocks come off easily, you don't need the beam off. Ride height is determined by the torsion bars(springs) not the dampers. A knackered damper may give a slight discrepancy in ride height but probably not 15mm.
Remove both dampers with the car on flat ground and re-check your ride height.
Facebook
Posted 17th Oct 2014 at 20:48
Sounds like bearings in beam are shot new shocks won't help
Posted 17th Oct 2014 at 21:04
jord294
I agree Thumbs up
Posted 17th Oct 2014 at 22:37
luke89
The service history has a receipt for a rear beam overhaul less than 2k ago which tends to make me thing either they didn't change the bearing OR they did a crap job of resetting the rear beam.
Posted 17th Oct 2014 at 23:47
allanallen
Sounds like they've just set it wrong or fitted the arb with a load of preload perhaps. Should be easy enough to rectify although a bit more involved than changing the dampers.
Facebook
Posted 18th Oct 2014 at 07:05
luke89
How much would you charge to have a look at it Allan? You aren't a million miles away.
Posted 18th Oct 2014 at 12:44
chiefton
Iv had a few iv worked on thst sit lower/higher on both/one side because of knackered shocks,but as with anything you wont know till you look properly
cherry rallye daily (the money pit)
Posted 18th Oct 2014 at 13:47
