As Peugeot built it with the later motor without the washer going through it, you'd think they would fit the plastic arm also. 'Parts Bin Special' as they say...
The plastic ones look nicer, so I want to get one. Removing used ones often ends in breakages so I will look at buying a new'un. The part number I've got from Service Box is - 6429Q5 which is the arm Since XXXX, so I'd assume is the latest one they did. The picture does show a metal arm though. I suppose I can't blame them for using the same image, but just wanted to check if anyone had purchased a plastic rear wiper arm from Peugeot - is that the number you used?
- just doesn't look right to me, but its an individual choice
