Author Subject: Grinder time?
pauldoubleyou
This 6 has one of those clamps installed that goes round the gearstick, and clamps it to a plate. The plate is bolted to the floor. I'm in the process of removing it however it's in with security bolts the likes of which I've never seen. Any ideas of how to remove?
They have no heads inside the car, just smooth caps.
Paul
Hiding with Pride
Posted 27th Sep 2014 at 12:41
they would have had snap off heads on the inside originally.
chop/grind or weld nuts to the bolts.
Posted 27th Sep 2014 at 12:55
jeffers Forum Admin
Yep they're shear bolts. Grinder will be the only way....
Team Running Engine again!
Team Negative Camber!
Posted 27th Sep 2014 at 17:16
pauldoubleyou
Did the above, ground the heads off and they dropped out. Just got to weld the holes up now..
Paul
Hiding with Pride
Posted 10th Nov 2014 at 20:17
I'd just put bolts in the hole tbh Razz
Posted 10th Nov 2014 at 20:31
