Author Subject: Running hot
peugeot96
My GTI6 has started to running hot when standing still on tickover, the needle getting close to the redline before one of the fans kicking in. When driving, the temp only reach 70-80 deg at the gauge. But the temp goes quickly up to hot when driving in slow traffic.
Posted 11th Sep 2014 at 11:18
Check the relays.
Posted 11th Sep 2014 at 11:48
peugeot96
Located between the fans??
Posted 11th Sep 2014 at 13:21
jeffers Forum Admin
Yep! Thumbs up
Team Running Engine again!
Team Negative Camber!
Posted 11th Sep 2014 at 19:41
peugeot96
Only one fan kick in, swapped the relays, but only the same fan kick in.
Posted 11th Sep 2014 at 21:22
Pull the brown plug from the thermostat housing ? This will cause the fans to kick in ? This will show if both fans are functioning ?
You can bridge the ac loom plug so as to use the ac button to activate the fans ?
Bitron unit behind passenger arch liner is the usuall problem to fans not working
Posted 11th Sep 2014 at 21:37
cully
if one fan is fobared you wont get slow speed only fast speed from the good fan
both fans should run when on high speed
id change the fan thats not working
Posted 11th Sep 2014 at 21:49
peugeot96
Brown connector out, but only one fan started, switched the relays but the same fan started.
Posted 11th Sep 2014 at 22:08
Bitron unit behind inner wheel arch passenger side is my bet ?
Also check loom plug to fan housing for corrosion
Posted 11th Sep 2014 at 22:14
Puggitt
I've got a pair of working fans if it the motor that's buggered, also check engine bay fuse box the 40 amp ones
Posted 26th Sep 2014 at 01:27
