Author Subject: Few bits
Standard GTI torsion bars blasted and powder coated dark red by Jord on here, SOLD
Phase 3 Clear front fogs in reasonable condition, SOLD
Moonstone phase 3 front grille, £20 posted
306 HDI home made decat £30 posted
Yuasa YBX3027 battery from 306 HDI, 60AH 550A EN less than a year old cost about £70 new iirc £20 collected from Kent / Sussex if anyone wants. Will test properly with print out but turned over the HDI very fast.
GE quickshift, decided I prefer mine without now I have a shortened gear lever,
These are prone to slipping (as I found out) so I drilled out the clamping bolt hole and put a larger diameter bolt through and never had a problem since. £15 posted.
Probably more stuff kicking around to be honest.
Posted 12th Sep 2014 at 13:10
matt_w
PM sent about the torsion bars
Posted 9th Sep 2014 at 13:42
Stuwee
I will take the fogs.
Pm me your payment details please.
Ph1 Cossack 6
Posted 10th Sep 2014 at 23:48
Bumpy
3gan
short shift sounds good
does it use existing reverse lever etc?
Posted 13th Sep 2014 at 00:33
Works like most do mate just bolts onto the existing lever on the back of the box. The lower down you bolt it the shorter it makes the throw of the lever. Clip the longest gear rod to it instead of the lever. Google "GE Quickshift" if you want but I'll take it off the car tomorrow and put up a pic.
Posted 13th Sep 2014 at 00:37
Bumpy
Posted 18th Sep 2014 at 14:04
